Old 11-26-2008, 12:36 PM
apatti apatti is offline
Default Building up cowling edge
Question for the fiberglass gurus...
I need to build up the front outboard edges of the cowling inlets on the bottom half a fair amount (about an inch). In order to make a more solid connection between the existing cowling edge and the area I am adding I am considering the following:
- cut a couple of slits along the edge to be built up perpindicular to the edge
- glass in to those slits short pieces of cut up hinge pin so that they protrude up into the area to added
- build up the area with cloth and epoxy/flox mixture
- sand even
Does this sound like it would help the new section grip and stay put?
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
Old 11-26-2008, 07:11 PM
DanH's Avatar
DanH DanH is offline
Tony,
Best to post a picture illustrating what you want to do.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-27-2008, 06:29 AM
N131RV N131RV is offline
Default Blend edge for strength
- sand even
You need surface area to get good adhesion and strength. Easiest way to do this is to create a lap joint.
1/2" to 1" will be plenty of overlap. Simply create a lap joint by thinning the edge before you add your new material. It will be much stronger than a butt joint.
Just a suggestion.
YMMV.
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
