11-26-2008, 08:15 AM
If no electic trim
If I choose to have manual trim vs electric where would the trim switch/trim roller be located in the cockpit? Between the sits??
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
11-26-2008, 08:34 AM
In a homebuilt, you could put it where ever you wanted to. But, the plans put it on the floor below the throttle. Kind of sticks up between the pilot and passenger's knees.
I really like manual trim, btw!
Jeff Rhodes - Taylorsville, GA
RV-9, 7 - going fast
BC-12D - going slow
jrhodes@v1salesmgt.com
11-26-2008, 08:58 AM
Quick question about manual vs electric.
I've got a handful of hours in a DA-20 some time ago and found that the electric trim was NOT accurate enough for liking.
How accurate is Van's trim for getting the aircraft trimmed perfectly. Manual trim, I found so far on most aircraft, you can't go wrong.
Adam D. Oke
11-26-2008, 09:04 AM
Which RV are you building?
On the side-by-side RV's the manual trim knob goes just in front of the main spar, between the two seats, down by the floor, just forward of the fuel valve. See this picture.
I think on the -3, -4, -8's it goes down low on the left side, below the throttle.
Is manual trim even an option on the -10?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-26-2008, 10:51 AM
I am building a 7. Is the eletric trim worth the 300.00.?
Ryan Allen, CFII
E-170/175
11-26-2008, 10:53 AM
I'll let you know in about 3 weeks or so...
In "non-RV" aircraft I've found that I like the manual trim a lot better because there's good feedback. There's a feel to moving a wheel or turning a crank that just pushing a button doesn't give. When I fly aircraft with both - Piper Arrow, Bonanza, SE Cesssna - I usually use the manual wheel and not the electirc yoke trim button.
BC-12D - going slow
11-26-2008, 03:11 PM
FWIW------------ I absolutely "love" the electric pitch and roll trim in my RV6A. And I don't have speed controllers either.
In fact, a 9A driver commented on how well my trim works! It just seems to settle right in, without that too little or too much scenario.
Just last weekend, as my wife and I flew a 7.6 hr cross-country......... I asked how'd she'd like it, if I had to reach down between the seats everytime to twist a trim knob instead of merely tapping the 4-way trim switch on my joystick. And it would be even worse, if it was attached to a center post which steals knee room. Needless to say, we both much prefer the little trim button on the stick!
I can't even imagine grabbing between the seats for a "flap handle"!  Yes, mine is certainly electric too!
L.Adamson --- RV6A
11-26-2008, 03:12 PM
If they had electric, I used it! Same with my RV.
L.Adamson --- RV6A
11-26-2008, 03:29 PM
To each his own, I guess. That's why you build an an expirimental. Do it the way you like it.
BC-12D - going slow
11-26-2008, 04:03 PM
Does the 9 need a trim speed controller?
Does anyone know if the 9(A) electric trim is as sensitive or touchy as the 6 & 7's are supposed to be? I've built for either but will have to decide soon and I'm leaning toward electic so I can have the autopilot manage it if I want to.
dave
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
