Old 11-25-2008, 04:34 PM
llavalle's Avatar
llavalle llavalle is offline
Default Fuselage width, RV-6 VS RV-9
Last weekend, I had the chance to see an almost finished RV-6 from a builder I know (Denis Lussier, I don't know if he's active here)
He has the Classic AeroDesign interior, including the "Aviator" side panels. While I was in, I found it akward that I could not get the stick to full left. It was hitting my leg before the stop.(I'm not a small guy). I contacted Classic Aero and they told me that the aviator side panels reduced the effective width of the fuselage and that the "Sportsman" armrest did not...
My question is : is the RV-9 fuselage wider compared to the RV6... If I install aviator sidepanels, will I suffer the same problem?
Thanks!
Philippe Marseille
RV-9A Kit Emp done, wings @50% - SOLD
RV-12iS@Empennage
Construction Web Cam
Old 11-25-2008, 04:38 PM
Mel's Avatar
Mel Mel is offline
Fuselage width of the -6, -7, & -9 are all the same.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-25-2008, 04:42 PM
buz buz is offline
No need to worry. I have an rv6 and very thick legs and also cannot hit the stops. If you need to take it to the stops in flight you have bigger problems.
Jamie Busby
AT-502B
RV-6 Sold
RV-10
Old 11-25-2008, 04:49 PM
llavalle's Avatar
Wow, that was quick! Thanks.
The email I got from Classic Aero noted something about the height of the fuselage.
I don't think the 9s are any wider at any point when compared to the 6, however the fuselage in the 7 and 9 are deeper. To confirm this, I just looked at some of our lower cabin panels (the ones that go below the armrest). They are approximately 1" taller than the panels for the 6. What this means is that the armrest side panel will be about 1" higher in relation to your seat cushion.
Is the actual fuselage deeper?
Philippe Marseille
RV-12iS@Empennage
Old 11-25-2008, 04:56 PM
Mel's Avatar
Mel Mel is offline
No. It is not deeper. The seat pans in the -7 and -9 sit lower to give you more headroom.
Old 11-25-2008, 04:57 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Same here.........
You don't get close to the stops for even steep turns. It's surprising just how little the ailerons actually move, to do what they do.
L.Adamson -- RV6A/Sportsman seats
Old 11-26-2008, 07:15 AM
pierre smith's Avatar
Default You don't get close to the stops during rolls...
.....either Four point hesitation rolls either.....and we have the Classic interior and sides.
Regards
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
