permatex High Performance Thread Sealant
Is Permatex Thread Sealant good to use for nuts/threads on my fuel lines? It says it is for use on metal and fuel, oil, hydraulic fluid. I got it to use on the nuts that hold my fuel return line and vent line to the blue fittings that exit the inboard rib of the tanks? And I thought I might use in on the flop tube nut to the blue fitting also. Is this the right stuff to be using for these purposes? I figured it would help seal, and hold the nut from vibrating off. Right? Or is this a product to steer clear of for airplanes? It says its major content is Polyglycol Dimethacrylate Ester.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
