pedal bow
Yep, I had that issue as well, I was able to tweek mine up with a slight bend in the tube. I used a straightedge to identify the direction of the deflection, and clamp it up to remove the bend. Got it on the first try. Also, make sure the powdercoat doesn't interfere with the bearing blocks. I had to remove a little from the ends and middle to ensure smooth operation.
Hope this helps,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
