Hi all:
I know there are multiple threads dealing with this, but couldn't find exactly what I am asking.
I am about to close up the left fuel tank with the baffle, and wonder if I should route a fuel return line in there before I do. How big should the line and fitting be, and which bay should the line empty into? Also, should I be running these return lines into both tanks or just one of them? I don't know too much yet about the mechanics of FI systems, so I don't know if it is even possible to run the return line from the engine into a tee, with two lines coming out...one for each tank.
I don't know yet whether I will be going the FI route yet or carborated, but it seems smart to think about this now. I could always cap off the line if it doesn't get used.
Do some guys run a return line after the fact, and run it along the back side of the baffle and go into the bay of ones' choice?
What say you guys?
