Originally Posted by Bob Axsom
You can use knife splices with sleeves tied over them for short protection. That is what I use for my wing tip lights to make my tip tanks and stock tips removable. You can buy them from Aircraft Spruce but they call them something else as I recall.
Bob Axsom
Knife (Handshake) splices work well for the this purpose if you are removing and replacing tips/tailcone often. Even then they're not bulletproof.
I was helping a friend with an annual inspection on a Beechcraft Baron last week and the white tail position light was inop. No voltage at the center post. Pulled the tailcone off and wiggled the knife splice around a bit and now we have voltage.
My preference is to use crimp style butt splices. Be sure to have more than adequate wire length so that you can remove and replace the tips/tailcone several times. Just cut the butt splice off as short as you can, then crimp the wires together with new butt splices when you replace the part.
With properly assembled butt splices, you know that you have a good connection.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
