Some 320s (including mine) are conical mount; others are dynafocal. I *think* that just about all the 360s are dynafocal. If you have a dynafocal 320, a 360 dynafocal should bolt up to the mount.
Can't swear to it for the -4s, but on the -7s the 360 mount is shorter (firewall to back of engine) than the 320 mount to keep cg in the right spot with the different weight engine.
Charlie
