Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-19-2008, 07:36 PM
Default 695/696 box inventory and "Lap Mount" info.
I ordered the 695 from Aircraft Spruce with a lap mount and a 12/24 charging cable. The 695 came yesterday.
There is no obvious box inventory in the box I received. That causes a little head scratching. There is a box inventory for both units at the Aircraft Spruce website and it was complete and consistent with what I found in the box.
One of the items in the box was a 12/24V charging cable so I was able to cancel one back ordered item.
The $50 lap mount caused me some concern because of the name. I could imagine something that extends across my lap (like my old IFR lap board) and block the stick movement. I called Aircraft Spruce and they did not know the configuration but they gave me a number to call at Garmin. I called Garmin and talked to the aviation specialist about it. I explained my concern and She did not know the configuration but said they are not expected to be available until mid December. I called back a little later and got the same specialist. I asked her to give me a phone number for the engineer or company that is developing the mount knowing that it is a question that could be answered by them. She said that she had checked into it since my earlier call and learned that the lap mount is being developed "in house" and that it is being developed specifically for aircraft that are controlled by a stick and it will not interfere with operation of the stick.
Bob Axsom
Old 11-19-2008, 08:49 PM
mburch's Avatar
mburch mburch is offline
I've seen the lap mount... it basically works just like a kneeboard. You can put it on either leg.
Also, here's the box inventory: https://buy.garmin.com/shop/shop.do?...59#inTheBoxTab
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 11-19-2008, 09:05 PM
Ironflight's Avatar
VAF Moderator / Line Boy
That woudl be pretty cool! I have been usinbg mine mounted to a RAM ball on teh right side of the cockpit, and have worn my kneeboard on my left leg as a result - a kneeboard type mount would be interesting - although it is nice to have all the cabling installed in the airplane so I don't get wrapped up in it (I have it that way now).
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-20-2008, 12:04 AM
Bevan Bevan is offline
Default 696 Mount
Paul,
Nice videos. Thanks for taking the time. Did I miss it or did you not post a pic as to how you mounted the 696?
Thanks again.
Bevan
RV7Wiring
