Originally Posted by CESSNADON
The blade covers look great and should do a very good job of keeping the blades clean. I wouldn't expect then to prevent impact damage though. If you unfortunately rap the blade trailing edge with a length of ,say pipe, you are going to vut the cover and still end up with a ding on the blade......
Forgot to mention that this material has a very thick backing so there is a little protection.
Obviously, if you're going to put the blades in a situation where there could be severely damaged by a pipe then you either have to build OSHA approved covers, or you deserve what happens.
The purpose of these covers is mainly to protect from scratches, such as when you're removing the lower cowl, or just walking by with a tool or a part in your hand and you just brush a blade. This will at least avoid a scratch.
When I'm wheeling the One Design back into it's parking place, I have to nest the nose into a corner that full of stuff. No matter where I position the blades, even tho I have marks on the floor to position the tailwheel, if I go too far, one of the blades will make contact with something. This will afford some protection.
Part of our winter project is to re-locate (throw out) some of that stuff!!
Jack
