Old 11-16-2008, 11:54 AM
Default 696 & 695 Approach Plates not Geosynced
I ordered my Garmin 695 after talking to Garmin tech services. I am very disappointed the the aircraft position is not displayed on the Approach Plates. This is such an obvious safety of flight item that I know it had to have been considered. Either it is a technical problem that the developers have not been able to overcome or som legal or risk issue. If I didn't need it now I would wait until they overcome this issue.
The EFB status can only be maintained if you maintain the Garmin database ($395/year) AND the Jeppesen database ($295/Year). I plan on doing what ever I have to to maintain current approach charts and not anything else. It's an octopus and it has me by the ankle.
Bob Axsom
Old 11-16-2008, 01:07 PM
Ironflight's Avatar
VAF Moderator / Line Boy
You're absolutely right Bob - you don't see the aircraft position on the "white" plates. I wish you could too! But....once you bring the correct chart up on the appropriate page, you are one knob click away from the moving map which does show your position - a compromise, of course, but for me, I have the 430 that shows all of my horizontal guidance, and I simply keep the approach plate up on the 696 to reference my vertical guidance.
I suspect that the reason they aren't displaying th position of the aircraft on the plates is because the scale on each plate is/may be different, and they don't have a good way of compensating for that without measuring the difference for each chart - which they would have to do with every issuance. I'd bet that Garmin does nothing to the charts, just displays them, and to do more would add a lot of effort.
All guessing, of course.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-16-2008, 02:08 PM
Doug Pearson Doug Pearson is offline
Paul...Have you done any comparisons with the Garmin 696 to the True Flight Cheetah FL 210 or the FL 190?
Old 11-16-2008, 02:27 PM
Ironflight's Avatar
No, I haven't had the opportunity to use the Cheetah's, so I can't comment on them.
Paul
Paul F. Dye
Old 11-16-2008, 02:36 PM
Thanks....Doug
Old 11-16-2008, 07:26 PM
osxuser's Avatar
osxuser osxuser is offline
There is no 'scale' on Instrument approach plates, they don't even run true to scale on the same chart. I wish Garmin had used Jepp charts, I'd be a lot more tempted if they had.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 11-16-2008, 08:07 PM
N395V's Avatar
N395V N395V is offline
Look here http://www.vansairforce.com/communit...t=fl190+garmin
This is a comparison of the FL 190 and the 496. Some of the precision approaches on the FL190 are georeferenced.
Milt Concannon
