Old 11-14-2008, 10:17 PM
sglynn's Avatar
sglynn sglynn is offline
Default Scuffing Tank Skins and Ribs
What do you guys (with no leak tanks) use to scuff up your skins and ribs for Prosealing. I've used Scotchbrite and a plastic wire wheel, but I've heard I should be much more severe and use #40 sand paper and really scruff them up so the Proseal will stick and never leak. So what did you use and how deep did you make your scratches. Thanks
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 11-14-2008, 10:38 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Maroon Scotch Brite Hand Pad
I just used the normal 7447 Maroon pad by hand. I actually taped mine off with masking tape to keep the scuffing where I wanted it but that's just my obsessive nature. I did scuff two directions at 90 degrees to each other so I had a sort of cross hatch pattern but I don't know if that was really necessary.
I think the real key is CLEAN! I wiped and wiped and re-wiped the contact areas with MEK until the pad came up clean (no gray aluminum scuff residue) and made sure not to touch the areas afterwards. You really don't want any oils or grease where the sealant goes.
Both of my tanks were leak free. (Well . . . Ok the first one had a small leak in the rear inboard corner by the baffle where I didn't put enough sealant - fixed through the fuel pickup access hole. )
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 11-15-2008, 08:06 AM
Robert M's Avatar
Robert M Robert M is offline
Default Scotchbrite
I did the same thing, taped them off with masking tape to keep the scuffing where I wanted it and cleaned it alot with lacquer thinner - tanks sealed. Well the second one sealed - learned alot about placement of proseal during the first tank build.
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 11-15-2008, 08:31 AM
szicree szicree is offline
Default Stainless Steel "toothbrush"
Maybe the instructions have changed, but my plans said to use a stainless steel bristle brush. I think I got it from a welding supply, but I can't remember for sure. Gotta use stainless so as not to embed particles of dissimilar stuff into the alum. (i think)
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 11-15-2008, 09:18 AM
A moderate scuffing with scotchbrite worked for me. There is no need for a more aggressive treatment of the material.
The other keys to leakless tanks are:
- Properly clean the tanks before applying proseal. Naptha was recommended back in the day.
- Butter every rivet before you insert it.
- Butter the end ribs before you insert them.
- Apply a fillet of proseal along the transition between the end ribs and the tank skins.
- Be generous with the proseal when attaching the rear baffle.
It ain't rocket science. Its just attention to detail.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-15-2008, 09:30 AM
Hawkeye7A's Avatar
Hawkeye7A Hawkeye7A is offline
Default Here's what I did
On my first tank I did the Scotchbrite scuff. Had a couple small leaks in the corners of the baffles. On the second I used a bead blaster (one of the cheap HF ones; only about $15 IIRC) with #30 silica beads and the air pressure turned way down. Left a great rough surface. Make sure the skin is well supported laying flat on a table/bench. Did the same on the rib flanges inside and out. Second tank, no leaks! Of course, as mentioned by a previous poster, you will learn more about how to apply the proseal and will invariably do better on your second tank.
--Hawk Pierce
RV-7A Flying as of Sep 7, 2008
Phase One complete as of Nov 16, 2008
Finally painted!
600+ hours and lovin' every minute of it!
N728E
SE AZ
"I fly because it frees my mind from the tyranny of petty things."
--Antoine de Saint Exupery
Old 11-15-2008, 02:08 PM
NYTOM NYTOM is offline
Talking Worked for me too!
That's the same thing I did Steve. I was really scared of leaks with all the talk about them on this site. I also cleaned the mating surfaces as best as I could with Acetone. As a result, my tanks tested OK.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 11-15-2008, 04:56 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Sponge pad sanpaper
Masked the second tank to keep scuffs where I intended them. I used both scotchbrite pad and an aluminum oxide type sanding sponge. It was about 1" wide and on edge made a clean pass where the ribs were to go. Removed tape, cleaned really well with lacquer thinner and/or acetone, and remasked. Generous with the sealant and no leaks in either tank.
Alan
RV-9A Wings
N984AW Reserved
Old 11-15-2008, 04:58 PM
panhandler1956's Avatar
Default rotary wire brush
I used a pretty aggressive rotary wire brush on a cordless drill. No leaks during the test, although they haven't flown yet.
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 11-16-2008, 01:45 AM
Flying Scotsman Flying Scotsman is offline
We used a coarse grade sandpaper "flapper" thing in the cordless drill, and pressed down on it to make a good, heavily scuffed path along all rivet lines.
2 tanks flying on my buddy's -8, 2 more ready to go on my -7A. So far, no leaks in the -8's tanks after 150 hours or so.
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
