Old 11-14-2008, 04:56 PM
Sid Lambert Sid Lambert is offline
Default Master contactor question
Ok guys, I'm still trying to run down some electrical issues.
I found something today that is unrelated but I would still like to remedy.
The master contactor is wired from the battery positive to the switch on the panel then to the 3rd post on the contactor. It does not connect to ground like I am used to. The contactor is all metal but I'm not sure if it is a continous use contactor or a starter relay.
With it disconnected from everthing, the input side has no continuity to ground but the output side and the 3rd pole do. Can someone verify this is correct?
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 11-14-2008, 10:28 PM
SteinAir SteinAir is offline
Not what I'd call a "standard" continuous duty relay that we normally see on aircraft for master relays. You are correct in the fact that "most" of them use ground to trip the relay. If it were me, I'd probably get rid of it and install a normal one like 99.9% of airplanes have on them.
Stein
Old 11-16-2008, 05:17 PM
MCA's Avatar
MCA MCA is offline
Default See documents
Sid, Take a look at our Contactor Wiring document located here: http://www.verticalpower.com/documents.html towards the top of the page. It is an overview of the different types of contactors used in experimental aircraft, and step by step instructions how to wire them properly.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 11-17-2008, 05:44 AM
I think it was a starter relay. $20 later and it has a new master contactor from ACS installed in it. This time it works from a ground like I'm used to.
Sid Lambert
RV-7 Sold
