Old 11-14-2008, 04:43 PM
digidocs's Avatar
digidocs digidocs is offline
Cool Source for squeezer shim washers?
Does anybody have a cheap or local source for squeezer shim washers? A couple of the vendors stock them, but I hate to pay $7 shipping on a $2 item.
An AN 3/16" light washer is about .032" thick which I think is a bit thick to do fine adjustment.
-DC
Old 11-14-2008, 04:50 PM
Mel's Avatar
Mel Mel is offline
Actually .032" is well within rivet tolerance. Also, as you use these washers over time they become thinner.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-14-2008, 05:08 PM
digidocs's Avatar
Mel,
Will .032" also be an okay step size for dimpling adjustment?
-DC
Old 11-14-2008, 05:12 PM
Mel's Avatar
Mel Mel is offline
Shims shouldn't have much effect on dimpling. The dimple is complete when the dies bottom out. just don't over do the pressure when dimpling. You should need very little pressure. I use the pop rivet dimpler on all holes and use about 7-10 psi on the pneumatic puller.
Old 11-14-2008, 05:29 PM
Auburntsts's Avatar
Default 2 words...
... Adjustable set. It is worth every penny in my book.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 11-14-2008, 06:10 PM
rvbuilder2002's Avatar
I second that.
Get an adjustable set for the squeezer (pneumatic I assume) then you can adjust it the same as a hand rivet squeezer.
Scott McDaniels
Hubbard, Oregon
Old 11-14-2008, 06:21 PM
Same here.
Sure it costs about $25.00, but well worth it for the time saving.
If you need a an extra couple thou... just dial it in!
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 11-14-2008, 07:51 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs down I borrowed one...
Originally Posted by lorne green View Post
Same here.
...with an adustable set, and didn't like it. While I was riveting a long row of identical rivets, the adjuster turned on it's own....
I prefer my fixed one with shims. Thick and thin AN960 washers work well, and I only use the thinner shim I have occasionally.... it does help getting the correct "squish" on the smaller -3 rivets.
If you are careful, I bet you could grind down a thin AN washer to half thickness, and you will then have all the shims you need.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-14-2008, 08:02 PM
Gil, If you learned to work with faster to adjust tools, maybe you could get rid of the "Very Slow Build" designation
Scott McDaniels
Hubbard, Oregon
Old 11-14-2008, 08:49 PM
G-force's Avatar
G-force G-force is offline
I ran a line down the side of my adjustable set with a sharpie so I could keep an eye on it because, yes, they move with use.
Mike Sumner
Castaic, Ca
