Old 11-14-2008, 09:11 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Anyone have experience with Performance Engines in California?
La Verne, CA to be exact. Their website is
http://www.performanceengines.com/
I've asked them for a quote for 4 new cylinders with higher compression pistons. 9:1, 9.5:1 and 10:1
I'd appreciate any information or opinions from anyone who knows them or has dealt with them. I would usually order from a brand name like ECI but these guys have forged pistons for higher compression rations and I'm tempted to trick my RV-8 out a little. I want to be careful though - 4 new cylinders with pistons will be between $4,000 and $5,000!
Thanks.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 11-14-2008, 09:16 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
http://www.vansairforce.com/communit...rmance+engines
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-14-2008, 09:21 AM
rocketbob's Avatar
All pistons are forged, so why would theirs be any different or better. AeroInStock sells CT pistons, and they come in the flavors you want, and they're fairly inexpensive at a bit over $100/ea. Their website is http://www.combustech.com. If you order cylinders, pistons, and a ring set you're looking at about a grand a cylinder from Aero.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 11-14-2008, 03:50 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Default Good experience
I had a very good experience with Ron. He overhauled the engine in my
RV-6 (O-360). He picked it up and delivered it on time (two weeks).
My experience was very good and know others who feel the same. I do
know someone who would not recommed them however. My dealings with Performance were in July 2007.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 11-14-2008, 09:48 PM
Bubblehead's Avatar
Thanks everyone. I ended up ordering cylinders and 9:1 pistons from ECi in San Antonio. They were the experimental version that they sell and cost about $910 per cylinder. Also ordered the required inter-cylinder baffles.
Old 11-17-2008, 04:34 PM
larryj larryj is offline
Default Performance Engines
Stay away. If you look through the archives in VAF and Matronics you will find a series of posts regarding Ron Munson and Performance Engines. When I reached my point of exasperation I posted my experiences here and a lot of other bad experiences were revealed. Bottom line is that there are plenty of really good people/companies to deal with so why even risk dealing with someone risky.
Larry E. James
Bellevue, WA
Husky A1-C
Rocket (under construction)
