Old 10-10-2005, 01:30 PM
Leonard_Smith_nz Leonard_Smith_nz is offline
Default Baffles: Rubber sealing material
All,
The baffles and the black rubber seals are on! Casting a critical eye over the installation does lead me conclude that it would be better if I could fasten the different rubber strips together. This would decrease the risk of gaps appearing and ensure that the rubber always folds inward.
Any ideas on how to do this?
I appreciate that any solution has to easily reversable to allow the baffles to be removed at some point in the future.
Regards,
Leonard
RV6 in New Zealand
Old 10-10-2005, 11:46 PM
osxuser's Avatar
osxuser osxuser is offline
I like these:
http://www.aircraftspruce.com/catalo...lefastener.php
Unfortunitly there is no picture, but they are a male and female screw together fastner that is almost flush. They are made out of soft aluminum so if something wears, it will be them, not the cowl. Pricey they are, but probably the most elegant solution.
Old 10-11-2005, 07:55 AM
vlittle's Avatar
vlittle vlittle is offline
Originally Posted by Leonard_Smith_nz
All,
Regards,
Leonard
RV6 in New Zealand
Leonard: Here is what I did-- lacking lacing cord, I grabbed some dental floss and laced my rubber strips together at strategic locations. My wife donated the needle.
FMI http://www3.telus.net/aviation/flyin...wd_photos.html
Vern Little
RV-9A
Old 10-11-2005, 03:24 PM
terrykohler terrykohler is offline
Use a leather hole punch on the rubber and fasten with nylon wire ties. You'll find that they can probably be removed after about 20 hours of flight time as the baffles will have taken a "set". On the other hand, there's no risk of abrasion damage in leaving them on.
