Old 11-13-2008, 01:10 PM
prkaye prkaye is offline
Default Odyssey / Voyager
I just requested quotes for the Odyssey and Voyager (same thing but with smaller 8.4 inch screen) from aircraft spruce. The quote seems a little unreal... only $3485.00 USD. Can this be correct? Doesn't say if this price includes all probes and sensors, but if so it's waaay lower than the approx 6K it says on the MGL website. But I can't find a seperate probe package on the Aircraft Spruce website.
This seems like one of those "too good to be true, there has to be a catch" scenarios... for the functionality/flexibility it provides, this seems even better value than the Dynon Flight Deck...
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-13-2008, 01:13 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Check with Craig Vincent, he is an authorized distributor for MGL.
And, a regular poster here at VAF.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-13-2008, 01:14 PM
Brantel's Avatar
Brantel Brantel is offline
I doubt it was complete list of everything you need....
Go here:
http://www.mglavionics.com/
There you can actually build a system and get a full price.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-13-2008, 01:22 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default For a complete EFIS . . . . .
. . . . you have to add an SP-2 magnetometer for the compass and an SP-4 AHRS for attitude. If you want engine monitoring, you have to add one of the RDAC units and sensors. That's where the $6K total figure comes from. My understanding is that the units function just fine without these items (moving map, etc) you just don't have attitude or compass or engine monitoring without them.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 11-13-2008, 01:25 PM
Aaahhhh... well those are certainly central "features" of such a system! I wouldn't consider them "extras"! I think Aircraft Spruce's approach to advertisign this is a bit misleading and objectionable in that case.
Phil
RV9A (SB)
Ottawa, Canada
Old 11-13-2008, 01:33 PM
Default Flexibility
Well, I guess it's how you look at it. If all you want is engine monitoring, you could buy the unit, the RDAC, and the sensors. Or perhaps you really don't need attitude (VFR/day?) but would like to have heading info - so just buy the unit with the SP-2. Without anything, it's a pretty decent large GPS/Moving Map/Autopilot driver etc.
BTW - I have no affiliation with MGL avionics (but I'm really thinking seriously about buying one of their units )
Dan Langhout
Old 11-14-2008, 08:18 AM
N131RV N131RV is offline
Default MGL Odyssey
I have one (and an Enigma) installed in my new panel.
They sell as a modular system, very flexible.
I purchased the Odyssey, Sp4, Sp2, RDAC-XD and a few odds and ends for just under $5k new (a few months back).
I already had sensors so I saved a few hundred.
The Odyssey is a pretty amazing unit for the price. Like all complicated electronics, it has a learning curve.
I don't have any flight time on the system yet (my rebuild is getting close to done, though), but I have run the engine and all sensors etc worked fine. I have run the unit on battery power for many hours while tweaking my screens.
I don't consider the MGL website to be deceptive, it was pretty easy to see what was necessary for a "complete" system.
Mission requirements may vary. I can well imagine pilots who don't feel the need for the SP4 (AI) or SP2 modules.
With my setup, the RDAC drives both units, allowing full engine sensors to function independently on both screens. Air data is independent as well. Also have the dual GPSs.
I have less than 15K into my total panel now and it will be quite nice. All glass, "emergency" IFR capable, nice redundancy and battery backup to keep flying if main power fails.
So far, I am quite satisfied with my MGL products.
Just my 2 cents.
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 11-14-2008, 09:14 AM
Agreed... to clarify, I found the presentation on the Aircraft Spruce website to be a little deceptive.
Phil
RV9A (SB)
Ottawa, Canada
Old 11-14-2008, 12:07 PM
thallock thallock is offline
Default Not deceptive, just bad programming
I wouldn't go as far as to say they are deceptive. It seems to me that anyone wanting to buy a piece of equipment as expensive as an EFIS would have researched the product and know what is needed to put a system together.
However, I would say that Aircraft Spruce could do a little work on the MGL stuff. If you select MGL under their Avionics page, you see many of the items that MGL sells, but not all. They show all of the EFISs and a few RDACs, but only the SP-5. If you click on the Enigma, you see most of the pieces needed for a full system, even the SP-4. But if you click on the Voyager or Odyssey, then all they show is the individual EFISs.
I have seen this before on Aircraft Spruce. If you go to the fiberglass section there are a lot of the items that you might need, but a few things will be missing, and you have to explicitly search for those items that are left out. This is not "deceptive", they just have a lousy webmaster. I still use them, because they have a lot of stuff, but you have to know what you want.
Tracy.
Tracy Hallock
Austin, Tx
RV-7(EH) - Fuselage
http://www.trv7.com
Old 11-14-2008, 12:22 PM
Default Spruce web site
They do in fact, have all the MGL sensors listed, but they are listed under the Enigma page!
http://www.aircraftspruce.com/catalo...ges/enigma.php
Yow, AS, bad webmaster!
The Odyssey and Voyager are pretty new products. Hopefully AS will get their web act together.
Joe Portman
Rebuilt as TD
