Old 11-13-2008, 05:15 AM
rwshooter rwshooter is offline
Default wings here today
have a couple questions......do I need fuel tank dimple dies.....if so why? also where can I find pro seal that comes in a mixing tube... that you mix in the tube and dispense from the same? know I saw this somewhere awhile back just cant find it again....
Thanks.....Robb....7A
Old 11-13-2008, 06:04 AM
noelf noelf is offline
ProSeal that has been "proportioned" is available from Van's and ACS (among others).
When you are ready for the final install of the tank ribs and the tank skins, you will smear a layer of tank sealant (proseal) between the parts as you put the parts in place, hold with clecos, and then flush rivet. The proseal will ooze out of the dimpled holes (this is a good thing). When you jab a flush rivet in the hole, the proseal that ends up remaining in the dimpled hole prevents the rivet from seating completely flush with the skin surface. So, a slightly deeper dimple is desired to get the flush rivet to seat flush with the proseal (desired to prevent a leak).
I have also found that these tank dimple dies work well on the underlying dimpled holes of lap joints in many areas of the skin joints. This aids in the "nesting" of the top and bottom surface sheets.
Old 11-13-2008, 06:42 AM
Thanks noel.......great explanation........so you use the tank dies on the ribs and skins?
Robb....7A
Old 11-13-2008, 07:05 AM
It depends (engineering term)...As an example, I will dimple the skins and ribs with the "standard" 3/32 dimple dies. For what ever reason, sometimes the parts will nest correctly (no gap whatsoever) and sometimes a "slight" gap is present. When I detect a slight gap, I go back and use the tank dimple dies on the underlying rib. This then eliminates the "gap".
Some time ago there was a link to a Walt Disney produced animation that described how and why underlying skins and structures get different amounts of deeper dimples as the rivet joint is composed of more and more layers. This video was produced to help the war effort...back in the '40s...or earlier. But it is still relevant today.
I do not have an answer as to why the layers some times nest without a small gap, and other times a gap is present. It may even have something to do with material thicknesses...and as always, YMMV.
Old 11-13-2008, 01:03 PM
Gary Baker Gary Baker is offline
Default Buy the Quart Kit
Hi Robb,
I sealed my tanks last year. My recommendation is to buy the quart size of Proseal. You are able to use only what you need during that session. If you use the tube, then (I believe) you have to use the entire tube then or throw it away. It took me a little while to finish my tanks, so having the quart size made it much easier for me. I used Sam Buchanan's instructions, as well as Rick Galati's suggestions. Search fuel tanks and you'll find great info. I made some Word docs from the threads and websites. Let me know if you want a copy of anything. I found the process to be just another job to do in getting this beast flying! MEK works wonders in the cleanup. Just treat it with respect!
I did use the tank dies to let the rivets set properly after the Proseal was added to everything.
I added some of my photos detailing my process on my Picasa website, if you are interested.
Good Luck!
_____________
Gary Baker
VAF 737
RV-6 Flying since 5/31/14!
N927MG
Medina, OH
EAA Flight Advisor/Tech Counselor
Member-EAA Homebuilt Aircraft Council
Website: http://www.mykitlog.com/ggbaker
Photos: www.picasaweb.google.com/bakerfamilyenator
Old 11-13-2008, 01:25 PM
rleffler's Avatar
rleffler rleffler is offline
Robb....7A
Yes, because there will be a small amount of proseal under the rivet. Use the tank dies so the rivet doesn't sit proud of the skin.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-13-2008, 02:28 PM
Sometimes I provide too much info...out of context.
To be specific...use the tank dimple dies on the tank skins and the tank ribs.
Use the normal dimple dies on the other skins, and tank dimple dies on the underlying skin dimples when required.
Old 11-13-2008, 09:01 PM
Default Thanks
got it thanks guy's....was just makin sure on the tank die thingy.....gonna order those and some other items tomorrow.......still thinking about the proseal....tube=quick, easier, less mess?...should be if you have alot ready to assemble.....right?........right now I have my hands full doing inventory on the wings.........thank God for Pink Floyd
Old 11-14-2008, 05:09 AM
rleffler's Avatar
I think you'll find that you won't be going fast enough to make the premade proseal tubes economical. I used them on the trailing edges on my empennage. They sure kept things simple and clean.
On the RV-10, most people go through almost 2qts of proseal. That gets really expensive if you buy it in the tubes. McMaster-Carr does sell empty tubes that you can load. I thought that was a great idea, but have yet to use them.
I found on the stiffners, I really didn't need to go to that effort. I just mix the proseal on a paper plate and use a tongue depressor with the end sanded flat. I'll be starting on the ribs this weekend, so I may alter my technique.
Where I think I will loading the tubes and using them is when I come back to filet the edges and cover the shop end of the rivets.
Bob Leffler
Old 11-14-2008, 05:19 AM
derLuigi's Avatar
derLuigi derLuigi is offline
Default Tube-stuff is fast setting
The "tube-version" from vans (MC-236-B1/2 (3.5 ounces)) is of the fast setting variety (1/2 hour worktime), see:
http://www.vansaircraft.com/cgi-bin/...roduct=proseal
I'll use mine on a part of the empennage (elevator-stiffners) because I got a tube of this stuff, for the tanks however it might be a better idea to use the one with a 2-hour worktime.
Kind regards,
Mario
Mario from Aachen, Germany
RV-7, emp. done, wings close to being ready for inspection, canoe flipped and parts of the finish kit in just about every room of the house
2019 contribution sent - thanks for this awesome space DR
