Old 11-10-2008, 12:38 PM
rv7charlie rv7charlie is offline
Default manual to electric pitch trim on a -4??
Has anyone done this conversion, & are there plans for it?
This isn't about the merits of each; the builder of my -4 installed the manual trim cable on the 3rd lever of a throttle quadrant, and the lever action is backward (forward causes nose up trim).
I've got an old MAC electric trim servo & it just seems easier to install it than a Rube Goldberg affair to reverse the lever's action on the cable.
Charlie
Old 11-10-2008, 01:37 PM
vic syracuse vic syracuse is offline
Super Moderator
Cahrlie, early on there were some ofus who mounted the trim servo back on the aft deck by the tail, and used a bowden cable from the servo to the trim tab. It seemed to work quite well. It got rid of a whloe lot of weight, too.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
