Old 11-09-2008, 09:48 AM
zman zman is offline
Default Repaired Canopy Crack
I repaired a 6" vertical crack w/ weld-on liquid and filled the "crack stop-drill hole" w/weld-on #16 solvent cement. However, some cement did spill to the outside of the hole to the canopy and now I am left with the problem of cleaning or "Polishing-Off" the residual.
Does any one have a Polishing Procedure to try to remove the dried cement and blend in the repaired canopy crack ??
ZMAN
Old 11-09-2008, 10:45 AM
FrankK90989 FrankK90989 is offline
Depending how much glue? Wet sand 800,1000,1500,2000. Trying to sand the plexi as little as possible. Then buff with 3M Perfect-it 3000 (06062) then finish with 3M trizact spot finishing (06070) never letting it dry out! Clean cloth only!!! If using machine, buff with wool, finish with foam. WET. This 3M stuff is just like majic. If you sand into the plexi to deep you will see it a mile away
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 11-09-2008, 10:54 AM
thankx Frank, EAA had an article Nov 2007.."A Lesson in Plastic Repair" they talk about using the "Urethane Supply Company's -Headlight Magic restoration kit" to finish a canopy repair...Any thoughts...the kit uses wet-sanding pads from 120 grit to 12,000 grit, polishing cloths and buffing solution. Do you think this process is similar to your suggestion ?
Zman
Old 11-09-2008, 12:27 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Van's sells a plexi polishing kit also. It has the required sandpaper, liquids, etc.
edit: maybe not, as I don't see it anymore.
L.Admason
Old 11-09-2008, 02:49 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Are you thinking of the Scratch-Off kit?
http://www.vansaircraft.com/cgi-bin/...ct=scratch-off
Great stuff, much, much better than the sandpaper based solutions like Micro-Mesh.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 11-09-2008, 06:26 PM
L.Adamson's Avatar
Yes, that's it. I bought one a few years ago, but have been "chicken" to use it...
L.Adamson
Old 11-09-2008, 06:37 PM
N941WR's Avatar
N941WR N941WR is offline
ZMAN,
Could you give us some details on how you fixed these cracks?
Thanks!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-09-2008, 08:36 PM
After the initial shock of seeing the crack... my plan was to first stop drill the crack with a plexiglass drill then using a syringe feed "Weld-on 3 Cement" along the crack...let dry an...repeat several times to assure a bond. Fill the drill hole with Weld-On 16 cement...now to clean and polish the residue
http://www.tapplastics.com/shop/product.php?pid=131&
http://www.tapplastics.com/shop/product.php?pid=132&
