Old 11-07-2008, 10:38 PM
RyanM RyanM is offline
Default AD-41H subsitution for Tank baffle
I've installed my rear baffle and I was ready to install the blind rivets, and I've only have 7 AD-41H, and I need about double for one tank.
So, I have some LP4-3's and some AD-41-ABS, and MSP-42 rivets, can I use those instead? I'm wondering if they will be more leak pron since they not closed on the end.
I could order some of the called out AD-41H, but I won't be able to install those until next Thursday since I'll be traveling.
Thanks!!
Ryan
RV-7 - Wings
http://moener.blogspot.com/
Old 11-07-2008, 11:16 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I would definitely wait until you have the proper rivets. This isn't a place where you want to be wondering if it will leak.
Was your kit short some rivets?
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 11-08-2008, 06:41 AM
Mel's Avatar
Mel Mel is offline
You can use standard pulled rivets on the tank if you are not stingy with the proseal. The entire tanks on my bi-plane use standard pulled rivets. They are somewhat more prone to leak, but can be used if you are careful. Also when I cleaned out the slosh from my RV tanks, I used standard pulled rivets and have had no leaks. That was several years ago.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
