Old 11-07-2008, 11:57 AM
prkaye prkaye is offline
Default CHT and EGT
Does anybody fly without CHT and EGT guages? Would you even consider flying a new airplane without these?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-07-2008, 12:42 PM
Auburntsts's Avatar
All the time. However, I have not flown anything brand new or that wasn't owned by someone else. FWIW, I'm planning on a full engine monitor to take advantage of having all of that data that it will provide.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 11-07-2008, 01:54 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default CHT/EGT Worth the investment
A $1K investment in all cylinder temp values is the cheapest insurance you'll find in protecting and diagnosing your $21K engine!
"To be forewarned is to forearmed".
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 11-07-2008, 02:07 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I flew without ANY CHT or EGT gauges in many rental airplanes for decades....Lycomings (and Continentals) run pretty good without instrumentation. That said, the instrumentation is so cheap nowadays, and if it can save you a gallon/hour of fuel burn, it's not hard to see why most people put it in from the start. Especially when breaking in a brand new engine, seeing the CHT's, and doing something about an overtemp before you glaze the cylinder walls is pretty nice!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-07-2008, 03:33 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Either an EDM850 or a Dynon
http://www.dynonavionics.com/docs/EMS_intro.html
In most a/c running LOP properly will have a payback of about a complete TBO job for the fuel saving.
Makes sense to me!
DB
Old 11-07-2008, 03:43 PM
MCA's Avatar
MCA MCA is offline
Well, here's an example from the other day that saved me a bunch of time. I was idling the engine while on the ground for about 20 minutes when I noticed that #4 EGT was quite a bit higher than the others, even though the engine sounded fine. I tired to clear it with a high-power run-up and leaning but that did not do it. I then cycled each mag and noticed that the #4 EGT fell off and it ran rough only when the left mag was active.
So I shut it down, pulled the cowl, and pulled the #4 plug on the left mag. Sure enough the plug was bridged. Cleaned it off and everything has been running fine.
Without those gauges it would have been much harder to diagnose and even discover.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 11-07-2008, 05:41 PM
Adam Oke's Avatar
Adam Oke Adam Oke is offline
I'm not a fan of the CHT steam gauge particularly because I have yet to see one work effectivly. However, testing out a digi one may change my mind.
EGT is going to give the first indication of serious engine issues. Any aircraft I own will have at LEAST an EGT. It can save alot of money in the long run.
Adam D. Oke
Old 11-07-2008, 08:17 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
My Skipper has absolutely nothing.... and I'm saving for a "Ultimate Bar Graph" I just want that extra bit of comfort knowing that all 4 engines up front are operating right. I never understood a single cylinder EGT on a carb'd engine.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 11-08-2008, 06:40 AM
lucky lucky is offline
Default No Way, Jose.
No, I wouldn't. At the least I'd get a complete kit like GRTs EIS system if low cost low fuss is an issue. It's a complete self contained system that's expandable if you ever go on to use their displays. I'm helping a fella now in his test phase balance out his CHTs and EGTs. In cruise he consistently had almost 100 degrees difference between his CHTs and large average differences between the left and right sides and very large difference between front and rear cylinders. We've been able to record all the flight data, make informed changes to the baffle and bracket designs and are really dialing in balance.
It such a good tool for leaning and engine troubleshooting that it'll pay for itself not only monetarily but in peace of mind.
http://www.grtavionics.com/product.a...=2&featureno=9
Lucky Macy
EAA Tech Counselor/Flight Advisor
