Old 11-06-2008, 05:19 PM
prkaye prkaye is offline
Default install dipstick tube before hanging engine?
My dipstick and filler tube came in a seperate box with my engine. Should these be installed prior to hanging the engine, or is it just as easy later?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-06-2008, 05:31 PM
jsharkey's Avatar
jsharkey jsharkey is offline
They'll fit later and will just get in the way of fitting the baffles etc - now there is something to look forward to!
Jim Sharkey
Old 11-06-2008, 05:34 PM
jrvssgl jrvssgl is offline
Sharky is right. Install after the baffles are complete. Have Fun.
Old 11-06-2008, 10:52 PM
SportAvServ SportAvServ is offline
Default Dip stick?
The tube later, but did you check and see if you have the fitting for your oil pressure line installed on the accessory case just under the upper right (looking from the cockpit) engine mount?. Depending on the engine, it could be straight, AN 816-4D or at a 45deg angle, AN 823-4D, with a restrictor in it. You will more than likely have to remove the engine to install the fitting.
Rt
experence speaking
Old 11-07-2008, 08:26 AM
szicree szicree is offline
Dipstick can go on later but make sure you've got something plugging the hole. Dropping some baffle hardware in there would be a bad thing.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 11-07-2008, 08:41 AM
noelf noelf is offline
If the Oil Filler Tube is installed early, you will need to remove the tube later when you fit the baffles, and also when it comes time to attach the large engine ground wire (cable) to the firewall ground location...dependent on engine type.
If you really want to install it now, go ahead. Just don't bother to safety-wire the thing at this point. Later in the build process, having the tube in place will verify the tube to oil access door in the top cowl.
Old 11-07-2008, 09:25 AM
trib trib is offline
Default Replace the gasket
When you do install it, do yourself a favor and replace the paper gasket with a silicone ring available at your local auto store. The tubes are known to frequently leak as there is not a lot of compression on the paper gasket.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 11-20-2008, 01:26 AM
Hawkeye7A's Avatar
Hawkeye7A Hawkeye7A is offline
Default Install the tube later
Just a side note on something I discovered. It wasn't too bad a chore to install and safety the oil filler tube after the engine was hung and baffles completed. I did notice that the tube would rotate very slightly when removing the dipstick after I had wired it. I redid it the first cowling removal and it still rotated about 1/8" when removing the dip stick after rewiring it. Using the safety wire pliers to crank the wire clockwise always seems to result in some slack in the wire. This last time after running the wire through the loop on the tube I instead clamped the pliers at the appropriate point on the wire and manually twisted the wire COUNTER-clockwise for the required number of turns and secured it to the loop boss on the case. No more loosening of the tube when removing the stick. It seems that winding the wire clockwise would position it at the wrong location of the hole in the dip stick tube and result in some slack. I guess all the little details count.
--Hawk Pierce
RV-7A Flying as of Sep 7, 2008
Phase One complete as of Nov 16, 2008
Finally painted!
600+ hours and lovin' every minute of it!
N728E
SE AZ
"I fly because it frees my mind from the tyranny of petty things."
--Antoine de Saint Exupery
