Old 11-06-2008, 04:19 PM
dhall_polo's Avatar
dhall_polo dhall_polo is offline
Default plugs and preservative
My engine was pickled from aerosport. The prop has been slowly turned a few times working on the spinner and fiddling with the canopy. Now I'm at a point of wanting to run plug harness and cht/egt wires. I'd like to at least temporarily install the plugs so I can be sure of how to run the wires nicely.
When I remove the plastic plugs from the lower cylinders, perservative oozes out.
Is it ok to just let this drain and then install plugs?
Worth it to catch the preservative and pour it back in somewhere else?
Better to wait till just before first engine start to fiddle with plugs and nearby wire runs?
I'm about done fwf, but I probably won't move to the airport for a few months.
Old 11-06-2008, 07:43 PM
gvgoff99's Avatar
gvgoff99 gvgoff99 is offline
Default Why let it all drain out?
Don, As you know moisture is the big problem. If you are building in a place where you do not get a lot of condensation then, even in Georgia, you should be OK if you loose some preservative. Personally I would probably not worry about the loss of some of the preservative oil but I would attempt to put the spark plugs in fast enough to minimize the loss of the oil. If it is "oozing" this should not be too hard. It sounds like you are close enough to completion to not worry about corrosion.
George Goff RV-6A (Flying 3/7/2006 )(Houston, TX)
Old 11-07-2008, 10:13 AM
Noah's Avatar
Noah Noah is offline
I would consider preservative oil that has oozed out of your engine as being contaminated and not put it back in your engine. That's just me.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
