Old 11-06-2008, 03:57 PM
prkaye prkaye is offline
Default oil pressure fitting
I just looked at my overhauled O-320 engine, and on the oil pressure gauge fitting (where the VA-128 is supposed to go), they have already included a fitting. THe fitting is similar to the VA-128, but is brass-coloured, and it looks like the restrictor is in the other end. Should I take this fitting out and replace it with Van's VA-128?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-06-2008, 03:59 PM
Mel's Avatar
Mel Mel is offline
That fitting will work just fine. As long as it has a restrictor, it doesn't matter which end it is in.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-06-2008, 04:27 PM
CESSNADON CESSNADON is offline
I've been told that the restrictor is there to slow down the loss of engine oil if the tubing to the oil pres gage fails. It might also be there to smooth the oil pump pulsations... In either case I would use it rather than a standard fitting....
