Old 11-06-2008, 03:32 PM
N941WR's Avatar
N941WR N941WR is offline
Default Best color for the instrument panel
Originally Posted by Tumper View Post
Have there been any discussions about what is the best color for the instrument panel? Flat black?
Dean Eiland
RV-9
Emp
Dean posted this at the bottom of another thread and I thought it deserved a more prominent posting.
Let the debate begin...
Dean,
I'm not sure if the color matters as much as how glossy it is. You really want something to keep the reflections down
I've seen black, white, red, yellow, gray, tan, many different kinds of wood, blue, and many more.
In my case, I used a textured flat dark gray finish because that is what I wanted.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-06-2008, 03:35 PM
Randy Walls's Avatar
Randy Walls Randy Walls is offline
Probably not pink, I mean coral.
Randy Walls
Cessna 120
Old 11-06-2008, 03:53 PM
dealfair dealfair is offline
Default Panel Color
Hey gang,
I believe BEST is whatever you want and like.
My favorite panel was simply sprayed with Tempo Gray Primer. I thought it looked really good and was easy to touch up. Real easy to do also. If I scratched it, just got a cotton swap and lightly painted it and couldn't tell there was any problem. Also the gray is a neutral color that goes with just about anything.
Have seen many beautiful powder coated panels in black, blue and brown.
I'm having my current panel redone in ole Tempo gray primer. I've had several people say it sounds yucky; but when they saw my old panel their minds were changed.
Cheers all,
Deal Fair
RV-4
George West, TX
Old 11-06-2008, 04:02 PM
Mel's Avatar
Mel Mel is offline
Personally I like flat to semi-flat black. When I look at the panel all I want to see is the instruments.
Other colors add reflections.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-06-2008, 04:22 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Light gray.
Old 11-06-2008, 05:13 PM
rv8guy's Avatar
rv8guy rv8guy is offline
Being an old helicopter jokey, I like the flat black, but as was said before, the best color is the one you like.
Really recommend staying with FLAT, however
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
Old 11-06-2008, 06:20 PM
AlexPeterson's Avatar
I am very happy with the flat black I used. Just last week, I was looking to rendezvous with another RV, so I was really looking intently towards the 10 o'clock position. The reflections caused by the only really reflective thing on the panel (toggle switches and their mounting nuts) made it harder to see. I should find a way to make them "flat" also. When the sun is coming from behind somewhat, everything reflects back off the canopy, the question is to what degree.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 11-06-2008, 08:33 PM
SteinAir SteinAir is offline
Here I though Alex liked yellow panels...jeez was I way off!
Anyway, we do an awful lot of these, and while we've seen our share of "non traditional" colors like Hummer Yellow, Raspberry Champagne, Big Band Blue, Feces Brown, Mountain Dew Green, Lipstick Red and a few others the most popular are (in no particular order) Greys, Tans and Blacks. None of them very shiney, we always go for a satin finish. I personally don't like crinkled/textured panels too much (although some are very nice and we've even done some), but they are much more difficult to label, and much more difficult to keep clean. Never (or rarely) glossy. We have't yet had a chance to match DR's "Salmon/Nipple Pink/Coral/Pepto Bismol or whatever color that thing" is scooter!
Also, for your bright switches Alex, we have some really soothing and nifty colored toggle switch boots...and yes...we even have yellow!
Stein
Old 11-06-2008, 08:48 PM
Geico266's Avatar
Geico266 Geico266 is offline
I'm a Henry Ford kinda guy. "You can have any color you want, as long as it is black."
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 11-06-2008, 10:55 PM
Captain Sacto Captain Sacto is offline
Default Pea Green?
I had an Archer a few years back, and the Royalite part of the inst panel was...pea green. Although I never would have requested it, after a while (and especially in IFR) I kind of liked it.
And, as to the color I'll likely select, it will be a deep dark, almost reddish brown. I saw it in a high-end turboprop single (a TBM IIRC) and it resonated for some reason.
The matter is highly individual as others say above. Some folks think they get a better scan with a dark panel (moi for example) and others like a light, or even white colored panel.
I think it's hard to make a mistake. You'll adapt to whatever you choose.
Tom in Sacramento.
RV-7A, Emp Kit finished (only 2 yrs!).
Wing construction officially started.
N7877A Reserved. Planning to call it "The STREAKER"
VAF # 1635
