11-06-2008, 03:07 PM
circuit breaker issue/potter&brumfield
i have a circuit breaker/master switch panel that has breakers by potter & brumfield. has anyone had any intermitent voltage problems with this type of breaker. mine are about 9 years old. next time i have a problem i will check the voltage on both sides of the breaker to see if that is the culprit. thanks for any input.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
11-06-2008, 03:15 PM
Did it get wet?
I had a master (split cessna type) got wet and caused voltage fluctuations.
11-06-2008, 03:25 PM
water problem?
Originally Posted by asav8tor
Did it get wet?
water is not an issue. i think these breakers are of low quality though.
Ed D'Arcy
11-06-2008, 07:16 PM
All Breakers or Just Master?
When contacts are closed, there is always an arc (spark) whether or not you can see it. This arcing causes minute pitting on both surfaces because of the nature of the spark (while tiny, very hot). Over time, the contact surfaces may become quite rough, causing some of the characteristics you mention.
If you replace the unit and tear down the original, I'd love to know if this is what you find.
Good luck!
Michael
11-07-2008, 04:36 AM
circiut breakers only
the problem is with the breakers only. i am 90% sure it is the breakers. i am going to start replacing the suspect breakers and see if it gets better.
Ed D'Arcy
11-07-2008, 08:52 AM
Ed, are these the W28 series P&B breakers like this one?
I've used these and have had to replace a couple. The upside is that they are very low cost, compact and easy to mount.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
11-07-2008, 02:55 PM
thats the culprit
yep, looks about right. my plane is 8 yrs old with over 3,000 hrs on it. these electrical gremlins have been bugging me. nice to know i am zeroing in on the problem.
about how much are they and where did you purchase them?
Ed D'Arcy
11-07-2008, 06:36 PM
About $3.00 each at Digikey.
V
V e r n. ====
RV-9A complete
S-21 wings complete
11-08-2008, 04:32 AM
what kind of problem did you see?
vernon, i was curious how your breaker problem occurred ? the price is very cheap. thanks for the source. i have about 5 breakers acting up. how old were the breakers you replaced?
Ed D'Arcy
11-08-2008, 08:39 AM
I had trouble with a strobe breaker and a flap breaker after downstream failures.
In the case of the strobe circuit, a switch overheated and the symptom was a popping breaker. I replaced the switch and breaker.
The flap breaker would randomly pop and had to be replaced. Eventually the flap motor failed so it may have been trying to tell me something.
Neither of these were the fault of the breaker, but I don't feel comfortable using a breaker that's popped several times. They are so cheap that I just replaced them.
Age was not an issue.
Vern
V e r n. ====
RV-9A complete
S-21 wings complete
