Old 11-05-2008, 07:59 PM
prkaye prkaye is offline
Default torque for va-128
what torque should i use when installing hte VA-128 restrictor fitting into the engine?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-06-2008, 03:49 AM
mburch's Avatar
mburch mburch is offline
These fittings use tapered pipe threads, which you don't torque... here's a good description:
http://www.vansairforce.com/communit...75&postcount=3
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 11-06-2008, 07:42 AM
Default Thanks Phil and Matt
for well timed question and answer. Working on it now as well.
Old 11-06-2008, 08:12 AM
I've also been using a bit of fuel lube on the threads of tapered pipe fittings (especially in the fuel system), to prevent thread galling. I assume this is OK.
Phil
RV9A (SB)
Ottawa, Canada
Old 11-06-2008, 08:21 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default Fuel lube
Fuel lube on pipe fittings is fine. You can also use PTFE liquid lubes as well, like Permatex pipe fitting compound with Teflon. No Teflon tape on the airplane, except for pitot static fittings.
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
