Old 11-05-2008, 06:38 AM
danielhv's Avatar
danielhv danielhv is offline
Default Fuel Tank Access Cover...
Ok, so I may be missing something here, but who knows. I am using float senders... and I'm putting flop tubes in both tanks.... So the sender goes in the second bay yadda yadda... but where do I get the access plate from to cover the inspection hole? IIRC, the only one I have has the holes drilled in it for the sender (from vans)... I dont remember seeing a solid blank plate on my shelves...
Old 11-05-2008, 07:12 AM
Randy Walls's Avatar
Randy Walls Randy Walls is offline
Default I don't think you need one
I don't think there is any reason to cut the hole in the rib with your set up. If you already have cut a hole just make a new plate from some scrap and rivet it on with proseal.
Randy Walls
Cessna 120
Old 11-05-2008, 07:14 AM
airguy's Avatar
airguy airguy is offline
You will need Vans part number T-411.
Old 11-05-2008, 07:40 AM
danielhv's Avatar
I JUST got my parts order yesterday!!! How come the plans don't tell you these things??????
Old 11-05-2008, 07:43 AM
danielhv's Avatar
I don't have any scrap anywhere near .063....
Old 11-05-2008, 12:13 PM
Mel's Avatar
Mel Mel is offline
Daniel,
If you are making a new plate to cover the hole in the inboard rib and nothing will be hanging on it, it doesn't need to be that thick. .032" would work fine.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-05-2008, 01:39 PM
danielhv's Avatar
Originally Posted by Mel View Post
Daniel,
Gracias Mel, I already ordered the T-411's... Wonder if I can atleast get some credit if I send mine back... what sucks is one of them has been matchdrilled and deburred when match drilling the flange that holds the platenuts.
Old 11-05-2008, 09:09 PM
RV7 RV7 is offline
Default Same situation
Daniel,
I had the same issue just several weeks ago. As you, I ordered the blank cover. I used the original cover to make a reinforcement plate to mount the sending unit on the rear baffle. I'm not sure if the reinforcement is needed, but mounting the unit directly to the baffle seemed a little "flimsy".
Chris Williams
Rome, Georgia
RV-7 N129AW -Reserved
Old 11-06-2008, 05:59 AM
DaX's Avatar
DaX DaX is offline
Daniel - I just went through this. I made plates from scrap. Check out the link in my sig. And the T-411 is in the plans - look in the text on page 7-6 about halfway down (my rev is 3/2/06).
I did use the plate with holes in it to match drill the baffle for the float type sensor.
In response to Chris - I mounted my sender directly to the baffle with no reinforcement - seems stiff enough with the baffle riveted together.
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
