Old 11-04-2008, 07:36 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default Wish I knew more stuff
My airplane has a carburated O-360. Once in a while, in the last few months, there is an issue after the first start of the day. The fuel pressure goes high, around 7 or 8 PSI, and the engine runs very rough at idle. I think it would die, but I can keep it going by leaning to near idle-cut-off.
During and after the run-up things are much better and the engine always runs great at higher power settings. For the rest of the day there is no further problem.
I'm thinking this is a mechanical fuel pump problem but I don't know how the pump regulates pressure. This weekend, at a fly-in breakfast, I asked two different mechanics about the issue and they didn't seem to have any idea.
Do I just need to replace the pump or is there something else I can do? I have checked that the vent line is clear.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 11-04-2008, 07:46 PM
N941WR's Avatar
N941WR N941WR is offline
Larry,
Make sure when you test run your engine as you work through this problem to keep an eye on your CHT's so you don't glaze your cylinders.
Your carb should have been flow (bench) tested and the mixture should be set correctly. If this is not the case, check with the company you got the carb from.
It is possible that you need to have the thing adjusted. Worse case, it is around $600 to have it overhauled.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-04-2008, 07:55 PM
n5lp's Avatar
fugio ergo sum
Originally Posted by N941WR View Post
Larry,
I should have mentioned that this engine has about 1,000 hours on it, all in this installation. CHT is not an issue as this only happens after a cold start and only while at idle or near idle. This is an occasional problem only, which makes me think it has nothing to do with adjustments; wear, maybe.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 11-04-2008, 08:09 PM
mannanj's Avatar
mannanj mannanj is offline
Default Stuff
Larry:
Check your PM's
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 11-04-2008, 08:14 PM
Walt's Avatar
Walt Walt is online now
If 8 psi is flooding the carb then it's time to rebuild it, needle/seat/float assy replacement should do it. Check the new SB out on these so you get the latest and greatest parts for it. The fuel pump sounds ok to me, 8 psi is within limits.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-04-2008, 08:45 PM
N941WR's Avatar
I just checked my notes. The OH for my MA3 was $700 in December of 2005 and it was done by AVstar.
The thing was bolted on and worked as expected. 200+ hours now and no issues.
Bill R.
SC86 - Easley, SC
Old 11-04-2008, 11:58 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Only just...
...the usual specification is 0.5 psi to 8 psi at the carb. inlet. So the 8 psi is exactly at the upper limit.
If the guages are not very well calibrated, this could easily be above the limits....
However, at 1000 hrs, a new seat/valve assy would certainly do no harm...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-05-2008, 08:11 AM
n5lp's Avatar
fugio ergo sum
Default Thank you all
It seems the consensus is that I need to do some carburetor work. Now I have to decide whether to learn about it and do it myself or send it off to a good shop.
Apparently the mechanical pump doesn't really have a regulator but by design should only be able to put out so much pressure?
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 11-05-2008, 02:00 PM
Dennis Fox's Avatar
Dennis Fox Dennis Fox is offline
Default Engine Problems
Try looking on this site.
http://www.sacskyranch.com/eng.htm
Old 11-05-2008, 02:17 PM
Geico266's Avatar
Geico266 Geico266 is offline
Larry, unless you have a flow bench to test the carb you should send it in.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
