Old 11-04-2008, 02:31 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Evercoat Rage Gold vs. Evercoat Featherfill
For those who have used both, can you suggest which is better for the intial finishing of the cowl. Van's suggests using Featherfill over the epoxy coats, but I have a whole galloon of Rage Gold that I'd like to use if it would be at least partially effective at dealing with some of the imperfections and pinholes. Any thoughts?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 11-04-2008, 03:40 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Different stuff
Thanks.
The Reader's Digest version, Rage is body filler while Featherfill is a high build primer. Use the Rage to fill larger areas first then block sand to get the proper shape and form. The Featherfill can be rolled or sprayed on to fill pin holes and other small imperfections. Again, block sand.
Actually, any large voids should be filled with micro filler and epoxy and sanded to form.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 11-04-2008, 03:46 PM
fstringham7a fstringham7a is offline
Default RE:1/2 data point
Steve
I can only give 1/2 a data point. I have used rage gold. On the cowl as an example. Did the prelim cleaning/let dry. I then squeegied (sp) one coat of rage gold/let dry.....happens fast...and then sanded with 3M 120 open coat paper. Blew a stream of air over the cowl and recleaned. Did a second coat of rage gold followed up with the sanding. After cleaning with air gave it a good inspection and applied rage gold to any areas needing attention.....resand.....will it ever end. Finally ready for primer!!!!!!
I have not used featherfill??
Frank @ 1L8 ...RV7A... still in the paint phase!!!!
Old 11-04-2008, 04:18 PM
Thanks Frank. Your experience is what got me thinking the Rage Gold might work fine. I just hadn't heard it anywhere else. Even if I have to touch it up later with something else (like Feather Fill) before I paint, I'm hoping the Rage Gold will be enough for me to get the worst of it so that I can prime the cowl gray and go flying.
Steve M.
Ellensburg WA
Old 11-04-2008, 05:49 PM
Default RE:220 Open Coat Paper
Steve
I forgot to mention that I used 220 open coat on the 2nd interation of the rage gold.
Frank @ 1L8 ...RV7A... Paint
Old 11-05-2008, 07:17 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Default went through the same issue
I just went through the same issue on the cowl prior to first flight and I used featherfill because that was what someone locally recommended, after two applications there are still pin holes in the cowling, on reflection I think I should have used the rage gold (I also have a gallon can unused) first and then the featherfill to finish later before I paint.
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
