Old 11-04-2008, 01:37 PM
Default Ignition Wire Baffle Pass Through?
Many Lycoming installations use a 2 wire plastic pass through device for the upper cylinder ignition wires, I've seen them and used them in the past but they seem to be no where to be found these days.
I have looked at ACS, Wicks, Chief, and every page of the Van's catalog, no one has them. What's the deal? Does anyone have a source for this device?
Thanks in advance.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 11-04-2008, 01:42 PM
Brantel's Avatar
Brantel Brantel is offline
ACS has them...
http://www.aircraftspruce.com/catalo...affleseals.php
Aero InStock has them as well:
http://www.aeroinstock.com/products/...ail/index.html
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-04-2008, 02:43 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Baby blue....
Originally Posted by Brantel View Post
...seems to be the present color from AC Spruce, not black like the catalog...
Vern L. posted a good pic of one recently...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-05-2008, 05:47 AM
[quote=Brantel;268869]
ACS has them...Aero InStock has them as well....
Thanks for Aero tip....I knew about the ACS units, they come from Lightspeed and are for 5mm wire (.196). The Slick wires are .25.
RV-12 Build Helper
RV-7A...Sold #70374
Old 11-05-2008, 06:24 AM
yakdriver yakdriver is offline
[quote=David-aviator;269065]
So get those and drill them out to.250. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 11-06-2008, 07:29 AM
Default BINGO
I called Unison-Slick service (they have not yet moved to the new owner) and got the straight skinny on the bulkhead pass through.
It is made by Slick and the part number is M2375. It is a 2 part device with a pass through hole just large enough to get the ignition wire end nut through. It comes with 2 (.25) wire holes for the 4 cylinder or 3 wire holes for the 6 cylinder.
The Van's baffle kit instructions say these devices come with the engine, but I guess they don't anymore as my engine did not have them and BPE said the engines do not come through with them these days.
AERO has them in stock.
RV-12 Build Helper
RV-7A...Sold #70374
Old 11-06-2008, 08:53 AM
mike109g6 mike109g6 is offline
Default Baffle
David,
My ignition harness came with a bunch, 1 - 2 - 3 hole versions, as well as the high heat adel clamps, attaching hardware, zip ties, etc. One whole bag of 'stuff', see here http://www.aircraftspruce.com/catalo...iteHarness.php
If your BPE engine has an aero-lite harness you may want to give them another call - it may have been accidentally left out. A friend recently got a BPE engine with Bendix mags and they left the P-lead ground kit out when it was shipped - $114 for the two kits from 'spruce'. BPE's great service sent him the two needed kits. Their service sold me-my next engine will be BPE.
Mike H 9A/8A
Old 11-06-2008, 08:59 AM
az_gila's Avatar
Smile Mine came...
...with the ignition harness, along with the "square" adel type clamps for holding multiple ignition wires....
Gil Alexander
Old 11-06-2008, 09:27 AM
Rick6a's Avatar
Rick6a Rick6a is offline
The Van's baffle kit instructions say these devices come with the engine, but I guess they don't anymore as my engine did not have them...
The bulkhead pass thoughs were in the hardware bag shipped with my new OEM engine and Lycoming tells me the items continue to be included.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 11-06-2008, 09:47 AM
Default interesting
My new Lycoming doesn't have those.
