Old 11-04-2008, 08:08 AM
Jeffsed Jeffsed is offline
Default main spar machine countersink
I'm working on the out board bottom skins of a 9 QB wing.
I want to machine countersink the main spar flange. The LE skin is already riveted on. How do you keep the Countersink cage square against the spar flange with the LE skin in the way?
Old 11-04-2008, 08:25 AM
cjensen's Avatar
cjensen cjensen is offline
Either "suicide" with no cage, or a much safer half cage is what you need...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 11-04-2008, 08:27 AM
b17fe's Avatar
b17fe b17fe is offline
Jeff,
I you will have to either find or make a countersink cage with part of the foot removed.
I don't know if I have any extras or not.
Steve Monigal
81604 Fuse (SOLD)
Old 11-04-2008, 08:39 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
How about a small piece of aluminum, the thickness of the installed skin, with a hole cut in it, to allow the cage to sit on top. Then just butt this up to the installed skin & set the depth deeper.
L.Adamson -- RV6A
Old 11-04-2008, 08:41 AM
b17fe's Avatar
Check your PM (Private Messages)
Steve Monigal
81604 Fuse (SOLD)
Old 11-04-2008, 10:05 AM
Thanks for the ideas.
Jeff
Old 11-04-2008, 10:12 AM
airguy's Avatar
airguy airguy is offline
L.Adamson -- RV6A
That would be my vote, right there.
