Old 11-03-2008, 03:08 PM
RyanM RyanM is offline
Default Twisted Tank Vent Line
Hello,
Well, I made a mistake. I over torqued the AN fittings for my vent line inside my tank. As a result it twisted the tubing. I wasn't thinking and had the torque wrench set to 100 inch/lbs.
You can see a picture here (at the top of the picture)
Now, I've undone the fitting and inspected everything, and it looked good, and properly torqued it.
What if anything should be done? Should I replace any of the parts? Granted if these were pressurized fuel lines, I'd in a heartbeat replace it, but since its the vent line, I'm thinking it may be ok. Thoughts?
Ryan
RV-7 - Wings
http://moener.blogspot.com/
Old 11-04-2008, 09:41 AM
...bump...
Thoughts Anyone?
Ryan
RV-7 - Wings
Old 11-04-2008, 09:47 AM
vic syracuse vic syracuse is offline
Super Moderator
That's really soft tubing, and you should be OK as long as there aren't any sharp crinkles in it. But, if the tank is really still open, I would be tempted to replace it for piece of mind. You could also put some proseal over the deformed area.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 11-04-2008, 02:31 PM
Bob Ellis's Avatar
Bob Ellis Bob Ellis is offline
Default AN Fitting Torque
Ryan. When you come to re-torque/torque the AN fitting AeroQuip give a simple alternative to using a torque wrench that works with EVERY AN fitting:
* Tighten the AN fitting hand tight
* Mark the AN fitting and an adjacent fixed point
* Tighten 1/4 turn
* End
Simplicity will always get my vote!
See this link for the download
Regards
Bob Ellis
www.rv-8.co.uk
Old 11-04-2008, 03:58 PM
Sparky's Avatar
Sparky Sparky is offline
Ryan,
Since I don't see any wiring installed to your capacitive fuel senders I assume you have not yet installed the rear baffles. If so, it is so easy and cheap to just replace the vent tube (for peace of mind as Vic stated above) I would replace it. It's probably OK to leave as is, but I see no compelling reason to do so.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
