Old 11-03-2008, 02:07 PM
Robert M's Avatar
Robert M Robert M is offline
Default 100 degree flathead socket screws
Anybody know of a good source for these in stainless - heck, any source!!??
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 11-03-2008, 02:10 PM
vic syracuse vic syracuse is offline
Super Moderator
Try microfasteners.com
http://www.microfasteners.com/catalog/products/SSC.cfm
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 11-03-2008, 05:21 PM
Robert M's Avatar
Default Micro Fasteners
Thanks Vic!
I have already talked to Bill Fleisher, just this morning. The SS screws that Micro Fasteners have are the "Torx" drive type. I was hoping to find hex (or "Allen") drive socket flat heads. If I can't find hex, I'll go with the Torx or as it is referred to in some places, 6-lobe.
Thanks again,
(author unknown)
FLYING since 2018
Old 11-03-2008, 06:58 PM
newtech's Avatar
newtech newtech is offline
The B-58 was put together with 100 degree stainless hex screws. Maybe my RV-7A would cruise as fast as the B-58's did if I use the same fasteners Oh well, guess I we would need stabilators to counter mach tuck. I am using the MicroFasteners "Torx" screws on mine.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 11-04-2008, 12:24 PM
kcameron kcameron is offline
McMaster-Carr is usually my first stop when looking for fasteners:
http://www.mcmaster.com/
Kevin Cameron - Fresno, CA - E79
N493DB RV4 Flying
IO-360-A1B, 10:1, Straight-Bore cylinders, Gapless Piston Rings, Hartzell CS Prop,
AFS3400-EE, TruTrac DFII VS, Aera 660, GTX 335, GDL 52R,
XM Radio, SL30, SL40, PMA9000EX, MicroTrac 300 APRS
