Old 11-03-2008, 06:56 AM
Steve Steve is offline
Default SB and logbook entry question
What would the correct phrasing written in the engine maintenance logbook to indicate compliance with a Service Bulletin, for example the latest SB from Marvel/Precision/Facet dealing with the new foam floats? Is the supporting documentation attached to the logbook or just kept on file?
Thanks all,
Steve
Old 11-03-2008, 07:10 AM
vic syracuse vic syracuse is offline
Super Moderator
Steve, just make the entry that you have complied with SB#xxxxx. If you complied with it by changing parts, then indicate that, as well as indicating that the aircraft is approved for return to flight, i.e., ground check, good/no leaks, magneto timing adjusted, etc, then sign and date the logbook.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 11-03-2008, 08:26 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Both...
Thanks all,
Steve
...remember that the FAA does not use the words "log book" anywhere in the FARs (or ACs, I believe).
They use the much more generic "maintenance records" ....so you can do both things you mention above.
One easy way of doing things -- A short entry in the log book and keep the supporting documentation in a three ring binder or similar.
Use a clear pencil holder to keep yellow tags from straying.
You can even use three of these holders to keep your three log books in the same three ring binder....
Together, the log books and binder become your "maintenance records".
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
