Prop for best glide with a dead engine
A fixed pitch CRUISE propeller or a counterweighted blade CS propeller. (With the loss of oil pressure, the CS counterweighted blades go to high pitch.)
I have routinely flown my RV-3 with both a fixed pitch cruise propeller and a CS propeller out of Camarillo Airport. (Camarillo Airport has a 3,000' displaced threshold. Pattern altitude is 800? AGL.)
With the CS propeller set at 2600 RPM downwind abeam the displaced threshold using full flaps at pattern altitude, I would pull the throttle to idle and immediately turn onto the base leg (nose way down). I would land in the first 500 feet of the runway.
With the fixed pitch propeller abeam the displaced threshold using full flaps at pattern altitude, I would pull the throttle to idle and fly the length of the displaced threshold and back to get to the same landing point on the runway. At least 5,000? farther than with the standard CS propeller.
I routinely fly my RV-6A out of Oxnard Airport. (Oxnard Airport has a 1,000? displaced threshold. Pattern altitude is 1,000? AGL)
With the standard CS propeller set at 2600 RPM downwind abeam the displaced threshold using full flaps at pattern altitude, I had to add power to have enough airspeed too flare for the landing. Without adding power, I think I can make the runway if I only use 20 degrees of flaps.
Regards,
Jim Ayers
