Old 11-02-2008, 09:04 PM
DanH's Avatar
DanH DanH is offline
Default Reality Check; Spinner Backplate
Quick check please. Pulled out my spinner kit today. The backplate is dished quite a lot, about 3/16" or so when you lay a straightedge across it. Is that common, or did I get the bad one?
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-02-2008, 10:12 PM
szicree szicree is offline
Mine was like that too. I asked on here and virtually nobody would admit to having one. I can tell you that if you try to undish it you'll end up with an out of true condition instead (ask me how I know this). After I screwed one up, the replacement was a tiny bit better, but still dished. I made sure it was true and went ahead with it.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 11-03-2008, 09:56 AM
trib trib is offline
No apparent dish on mine. I just put the spinner together within the past two weeks and both plates were fairly true.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 11-03-2008, 11:08 AM
pierre smith's Avatar
Default The prop will flatten it..
......pretty much to where it needs to be, Dan. Ours had a little "dish" as well when we first installed it. 410 hours now.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 11-03-2008, 11:42 AM
DanH's Avatar
<<The prop will flatten it..>>
Wish it was true <g> This one is going on a Hartzell CS; the backplate hangs on 4 hub bolts instead of being clamped between the prop face and the engine flange.
I think I'm going to treat this as an opportunity to build a "screwless" spinner.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-05-2008, 10:17 AM
DanH's Avatar
FYI, I spoke with Ken at Vans this AM. Ken says all available S602-1 backplates are dished, and pulling the S602-1 and S602B together won't hurt anything in the practical sense.
With the center removed per a CS Hartzell application, mine was still dished 1/8" when measured at the edge of the cutout. I did a trial assembly, fully riveted. The result is a lot of deformation at the rivet locations; obviously something has to give when you pull a dished part into compliance with a flat part. Personal choice; these parts are now patterns.
Don't think the dishing hurts a thing in a fixed pitch application.
Dan Horton
RV-8 SS
Barrett IO-390
