Old 11-02-2008, 03:01 PM
n468ac's Avatar
n468ac n468ac is offline
Question Garmin 430W ... need help...
Need help with our 430W trying to figure it out.
Question:
When flying the ILS with the 430W in VOCLOC mode it sees the ILS guidance and displays it on our GRT HX.
BUT ? when coupled to our TruTrak [FONT='Arial','sans-serif']DigiFlight II VSGV[/font], the autopilot fly?s to the final fix and the glide slope ? then the 430W quits sending to the autopilot and it (the autopilot) goes back to manual mode.
Is this normal?? Do you have to hand fly the final with an ILS?
When we fly a GPS approach the TruTrak will follow the 430W all the way to the runway without any problem.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 11-02-2008, 03:24 PM
mburch's Avatar
mburch mburch is offline
I remember reading somewhere that the 430W will stop sending out GPSS steering commands when it passes the FAF on a VOR/LOC/ILS approach. It's a bummer, but I think it said it was something to do with TSO certification, so what can you do.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 11-02-2008, 04:43 PM
SteinAir SteinAir is offline
From what I know Matt is correct. I think this was done for some certification and/or functional reason. You should however be able to run the analog ILS signals through your GRT which will continue to digest and regurgitate the signals as an ARINC....or get a Sorcerer (which watches both ARINC and analog), or fly a GPS approach which is as well know quite a lot more accurate than an ILS when available.
My 2 cents as usual.
Stein
Old 11-02-2008, 05:23 PM
Martin Sutter Martin Sutter is offline
Super Moderator
My Digitrak II VSGV flies the ILS beautifully. However to do that it has to be controlled thru the GRT EFIS. The ILS approach has to be armed in the GRT and the ILS frequency selected on the 430W. Your GRT has to be equipped with an ARINC module. On the auto pilot you have to select the GPSS mode for lateral steering and the GPSV mode for the vertical part. Also make sure you have NAV selected for AP steering and not Heading. This configuration will also fly GPS WAAS approaches including vertical steering. Mine even flies proceedure turns and holds but only after I used the latest version of GRT's software and hooked up a 3rd AIRINC out put from the 430W.
Martin Sutter
building and flying RV's since 1988
Old 11-02-2008, 07:05 PM
n468ac's Avatar
Thumbs up
thanks everyone.
I was hoping it wasn't a bad 430W or we missed wired something.
RV-6A - N468AC
N468AC Web Site
Old 11-03-2008, 09:08 AM
ddurakovich ddurakovich is offline
Martin Sutter
What about a missed approach? Can that be triggered from the GRT or do you need to switch AP source back to the 430?
Dave Durakovich
CFIG, AGI, COMM SEL, VAF# 133
RV-4, N666PR, Finished (Well, at least flying)!
RV-6 - Adopted an orphan!
Detroit, MI
"If you think you can do a thing or think you can't do a thing, you're right."
Henry Ford
Old 11-03-2008, 09:30 AM
Super Moderator
The auto pilot must remain under the control of the GRT to do the missed approach. Hit "suspend " on the 430W and "missed" on the GRT after passing the missed approach point. AP NAV mode should be on GPS on the GRT as the missed course is GPS driven.
Martin Sutter
Old 11-03-2008, 04:16 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Have you upgraded your GRT software to V32 and done the ARINC wiring mod?
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 11-04-2008, 04:53 AM
cleve_thompson's Avatar
cleve_thompson cleve_thompson is offline
I have a separate switch that selects input from the GRT EFIS or the 430W. If I want the TruTrak AP to fly the full approach with course reversals etc. as directed by the 430W, I must have the switch on the GRT side. With the newest software, I must have selected GNAV mode and not arm the ILS approach until just before I am established on final. This is also the time that the 430W automatically switches from GPS mode to VLOC if the approach has been loaded in the 430W. I also switch to LNAV mode on the GRT EFIS at that time. If I do my part, the TT will send me right down the slope. This also works with a VNAV approach.
I have found that if I want to fly an approach with vectors to final on a VNAV (WASS) approach, I must wait until established before arming the approach on the GRT EFIS. I had a time figuring that out! I had always wanted to get as many buttons pushed en-route before I got into the busy time and had been arming either the ILS or the GPS approach early. I had a few controllers really upset with me while I was trying to figure that one out.
I also found that if I had a LOC frequencyloaded in the 430W nav radio, I would not get a "glide slope" indication on the GRT EFIS on a VNAV approach. It works fine if a VOR frequency is loaded into the 430W.
One last little thing I have found on a ILS/LOC approach is that to select a tract on the GRT I must have the HSI displayed for the right hand knob to work.
The GRT is a great unit but some of the things that I found are required to fly a coupled approach using the GNS 430W, the TruTrak and the GRT EFIS are not documented!
Cleve Thompson
Waycross, GA
Flying a RV9A with O-320 from KAYS
since Dec 2007 & having a blast
Old 11-04-2008, 05:16 AM
n468ac's Avatar
thanks cleve, testing the GRT HX unit is next on our list.
RV-6A - N468AC
N468AC Web Site
