Old 10-31-2008, 08:16 PM
danielhv's Avatar
danielhv danielhv is offline
Unhappy Countersink shavings cutting skin...
Problem after problem. Im CS the bottom skins on the fuel tank (above the rear baffle)... these are for 426-3-3.5's... so we're not talking that big here. But it seems on every 5 or 6 holes I have one that looks like this...
It appears the shavings are staying in the cage and cutting the skins... The only way I seem to be able to prevent this is to CS for half a second, remove shavings, repeat until proper depth... What am I doing wrong here? I have tried using boelube with no luck. I am CSing with a cordless drill, so im not spinning it very fast... Im using the #40 bit that came with my Planetools RV toolkit. And Im using a cage that has the white nylon boot at the end to protect the skin...
Next question, How do I fix the ones that already look like this??
And I know some are going to say "Go get a no-hole bit", but I dont think these should be doing THIS!
Old 10-31-2008, 08:22 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Can't imagine shavings doing that!
That looks awful deep to be done by the shavings. I just did these, no lube, cordless drill on fast speed, no problems!
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 10-31-2008, 08:27 PM
danielhv's Avatar
Dunno what else it would be?? The picture is making it look worse than it appears to the eye... That was taken with the lense less than 2 inches from the hole.
Old 10-31-2008, 08:38 PM
Mel's Avatar
Mel Mel is offline
Daniel,
You may be using too much pressure causing the chips to be too large. Try running a little faster speed and less pressure.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
szicree szicree is offline
That countersink with the hole loves to do that. Get a no-hole c.s. and the problem will go away.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 10-31-2008, 08:44 PM
danielhv's Avatar
Originally Posted by Mel View Post
Daniel,
Ill give that a shot... how do u suggest I fix the ones that are there?
Old 10-31-2008, 08:45 PM
Mel's Avatar
Mel Mel is offline
I wouldn't worry about them. A little scotch-brite will take care of them.
Old 10-31-2008, 08:59 PM
danielhv's Avatar
Thank you sir!
Old 10-31-2008, 11:34 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Yes, this is what you really need to do. You've found the one drawback of the single-hole cutter. I have a couple halos on my tanks as well. I would countersink in at least two or more passes, increasing the depth on the second and third pass. That should address the problems if you don't want to spend $5-10 on a 3-flute cutter.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 11-01-2008, 07:12 AM
BrentHumphreys BrentHumphreys is offline
Could somebody show me the difference between a hole and no-hole countersink?
Are we talking about the flutes?
Brent Humphreys
PPSEL
RV-10 (Starting Empennage )
Status: Elevators
N411BE Reserved
Build Log
