Old 10-29-2008, 09:37 AM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Fuel Pickup Tubes
I decided I didn't want to use the stock pickup tubes in my tanks since I am planning on a dual pump system similar to frank's. The rotary vane pumps have 0 tolerance for **** getting in them of any kind so I am going with these sock type units. I know some of you feel an easily accessable filter is better, but in 30 years working on cars professionally, I can count on one hand the number of these I actually have seen stopped up. When they were, there was so much junk in the tank it had to be pulled anyway to clean it out.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 10-29-2008, 11:27 AM
airguy's Avatar
airguy airguy is offline
I like this idea a lot better than the slotted tubing pickups - where did you get them?
Old 10-29-2008, 11:51 AM
Don Jones's Avatar
Default They be Ford parts!
Kinda a bummer putting Ford parts on an RV, but I liked them better than the GM versions. They are part #D1AZ-9A011-A and are made to fit a 3/8 pickup tube. No mods necessary! I like simple!
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 10-29-2008, 12:01 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Another alternative
You can purchase a ready-made upgrade that includes a stainless steel finger but Van's accessory catalog does not have a picture of it.
http://www.vansaircraft.com/cgi-bin/...ct=fuel-pickup
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 10-29-2008, 12:26 PM
airguy's Avatar
I would prefer the plastic mesh for two simple reasons - first, the holes are much finer so it acts as a particulate screen much better than the metal one, and second because with holes that fine it acts as a fuel sock, and will preferentially pull fuel in while keeping water out due to surface tension - leaving your water to be drained out of the sump drain rather than being pulled into the intake.
I'll be going by the Ford house this afternoon...they are right around the corner and will likely beat Vans price for a genuine aircraft part plus shipping, not to mention being a lot faster.
Old 10-29-2008, 01:05 PM
asav8tor asav8tor is offline
The old saw slots would pick up the last drop of fuel (and some might argue, water). The ss mesh created maybe a minute or so less fuel pickup. The plastic one you show might leave a gallon or more unusable unless you have the pickup line angled down inside the filter. What keeps that thing from falling off the line? I would add the saw cuts on the line inside the filter. Then, if the filter fell off the open line would not be subject to plugging from debris.
Don't forget the anti-rotation bracket.
Old 10-29-2008, 02:22 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by asav8tor View Post
...Don't forget the anti-rotation bracket.
And don't forget to safety wire the nut per Van's Mandatory Service Bulletin.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-29-2008, 02:43 PM
Don Jones's Avatar
Default Can't fall off...
The aluminum tube slides inside a plastic sleeve which runs almost the entire length of the filter assy. It has pickup slots near the very end of this tube. It can't come off because it will run into the rear baffle long before it comes off of the tube. There is around 1" to 1.5" of aluminum slid inside and it is a very snug fit. It might leave a quart or so of fuel in the tank, however I never cut it that close on fuel anyway.
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 10-29-2008, 02:44 PM
scard's Avatar
scard scard is offline
Newer kits as in the picture above in Rick's post use the anti-rotation bracket to not only keep the fitting from spinning, but also to index the fitting nut to keep it from spinning.
Scott Card
CMW E-Lift
Old 10-29-2008, 02:45 PM
Don Jones's Avatar
Default Mine are like Ricks...
There is an angle bracket that locks on the nut and riveted to the plate. No way it's coming off! (It's just not on yet in the picture)
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
