Old 10-28-2008, 05:48 PM
szicree szicree is offline
Question 1/4-20 drilled head bolts
Trying to find four 1/4-20 drilled head bolts to attach my airbox. Found 'em for $43 for a ten-pack. Seems a bit spendy!
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 10-28-2008, 06:00 PM
grover grover is offline
Default a bit?
I'd be trying to make my own out of hardware store bolts at that rate. but then, I'm a tightwad.
james kleen
savannah
RV8sp
- RV3
Old 10-28-2008, 06:08 PM
N941WR's Avatar
N941WR N941WR is offline
Default Drill your own
Get one of these jigs and you will be able to drill all the bolts you ever need and it will save you money even though it costs $59.75
(Click on picture for details)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-28-2008, 06:28 PM
Gary Bricker Gary Bricker is offline
Thumbs up Gary Bricker
Are you wanting 1/4 x 20 threads per inch. If so go to Aircraft Spruce and get a AN4H-?A what ever length. That will get you a drilled head. Less that 1$ each.
Old 10-28-2008, 06:43 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Not quite....
..an AN4 is a fine thread - which is 1/4 x 28
Most Lycoming engine bolts are coarse thread, which is the 1/4 x 20 Steve asked about....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-28-2008, 07:09 PM
Angry Gary Bricker
Sorry, My mistake
Old 10-28-2008, 07:24 PM
Geoff
Posts: n/a
Default McMaster-Carr
Last year ACS quoted me more than that for a special low-quantity order, although I needed some extra-long ones because I have a spacer between the airbox and the injector.
I bought a drill jig and tried drilling some Grade 5 and Grade 8 bolts from the hardware store, but that didn't work very well for me (probably operator error).
I ended up ordering some 1/4-20 socket head cap screws (with a drilled head) from McMaster-Carr. Much cheaper and plenty strong enough.
Old 10-28-2008, 11:29 PM
G-force's Avatar
G-force G-force is offline
What length? I stock a few sizes in grade 8 or F911 at work, under a buck each if I remember right.
Mike Sumner
Castaic, Ca
Old 10-29-2008, 07:00 AM
lrfrey lrfrey is offline
Grade 5's and Grade 8's can be drilled if you have a drill press vice. Go slow, keep oiled and expect to brake a few drill bits though!
Larry
Old 10-29-2008, 08:05 AM
wilson wilson is offline
Default wag aero
AN74A-4. About $1 ea.
Greg Wilson
RV-7A, N718W
Tampa, FL KVDF
