Old 10-28-2008, 07:58 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Mikey Needs a new Alternator Bracket!
I'm hoping that someone might have a spare lying around....
Louise's RV-6 (otherwise known as Mikey) ate another alternator the other day - it turns out to be the 3rd one in 500 hours, which is quite excessive, but at least I now know why - I didn't change the earlier ones, but this one clearly has shot bearings, and the reason is equally clear - the brackets that attach it to the engine are clearly Kaput - and they were, shall we say, very "creative" in the first place.
This is a Boss mount (not case mount). It looks like both ACS and Vans sell a bracket kit that consists of three parts - two "L"-shaped pieces and the adjuster arm. I am looking for the style that is a single "U"-shaped piece, an adjuster arm, and the little link with the joggle that goes between the starter and alternator bracket. (No, I don't need the adjuster arm - this one is fine).
I see no reason to destroy another innocent alternator by putting it on the old mounts, but need to get the plane back in the air fairly quickly - does anyone have a lead on a spare?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-28-2008, 08:07 AM
Mitch757 Mitch757 is offline
Default Alternator Problems
Hi Paul,
After 500 hours on a Landol alternator, my mount broke. I ordered the Van's one and was amazed at the thinness of the material. I trashed the whole thing and bought the Plane Power unit from ACS.
It's a very first class unit with a very precise fitting and robust mount. You won't be disappointed.
All the best,
Mitch Garner
RV-4 flying
PL-4 flying
Old 10-28-2008, 08:09 AM
Mel's Avatar
Mel Mel is offline
Paul,
Let me check. I may have one.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-28-2008, 08:15 AM
Mel's Avatar
Mel Mel is offline
The one I have looks like this:
___I______I
2.25" 4"
If this will work, you're welcome to it.
972-784-7544
Old 10-28-2008, 08:25 AM
Ironflight's Avatar
Default VAF in Action!
17 minutes to a solution....can't beat that!
Thanks Mel - check your PM's for the address, and I'll let Mikey know that a transplant organ is on the way!
I've heard lots of good things about the Plane Power units Mitch - and they are a quality company! In this case, I already have the new alternator (we're standardizing our "Fleet" so that the two airplanes can share spares), so just needed a bracket - and if no one had one, I figured I could call PP and see if I could just get the part.
Paul
Paul F. Dye
Old 10-28-2008, 09:18 AM
mike109g6 mike109g6 is offline
Default Alternator Bracket
Paul,
I can also attest to the quality of Plane Powers parts/alternator. Has a case mount and straight out the box it fit perfectly for my 0-290D Nothing fits perfectly for that old engine, but Plane Power did. FYI - they sell replacement parts as well I'm told.
Good luck with Mikey, what a great name for a plane.
Mike H 9A/8A
Old 10-28-2008, 05:22 PM
frankh's Avatar
frankh frankh is offline
Default He he
I have an aluminium bracket like Mel if you want a spare..
Frank
Old 10-28-2008, 05:30 PM
Mikey's Avatar
Mikey Mikey is offline
Smile Thank you!
Wow! It is great to have friends like Mel and Frank to help spruce up a mature fellow like me. Thank you! I'm hoping to be ready to fly again when Louise get back from Orlando.
Mel, we missed you and Ann (and that handsome -6 of yours) at LOE!
Mikey - N164MS
RV6 born flying in April 1990 (4th kit out of the factory)
3000+ hours
Old 10-28-2008, 10:04 PM
Mel's Avatar
Mel Mel is offline
Default You're welcome Mikey,
Your alt bracket went out in this morning's mail.
