Old 10-27-2008, 08:24 AM
Brantel's Avatar
Brantel Brantel is offline
Default Question on the EA OIL COOLER MNT KIT
I just ordered my baffle kit and forgot that someone told me that the oil cooler doubler etc does not come with the baffle kit.
My question is what comes in the EA OIL COOLER MNT KIT?
My gut tells me that for 150 bucks, hopefully the doubler, oil lines and fittings, bolts, nutplates and spacers come in this kit.
What do the experts say???
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-27-2008, 08:42 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Default Parts List
Brian,
Here is the list straight from Vans:
EA OIL COOLER MNT KIT BAFFLE/COOLER ATTACH
1.000 FF-709 OIL COOLER DOUBLER
1.000 AS3-063X1X12 ALUM STRIP
1.000 AT6-058X5/16X15 7/ ALUM TUBE C-610
1.000 VA-134 OIL COOLER HOSE 19.0
1.000 VA-135 OIL COOLER HOSE 16.5
1.000 DWG OP-27A OIL COOLER/BAFFLE
1.000 BAG 620 COOLER ATTACH HDWRE
0.000 ZZZZZZZ EOK ZZZZZZ -----END OF KIT------
Hope this helps....
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 10-27-2008, 09:36 AM
Brantel's Avatar
Thanks Joe,
I just ordered what I needed from this kit to keep me moving and since I don't need the oil lines right now I left them out at this time. (read tight on funds at this time)
Do you know what is included in that BAG 620? They charged me $38 for it. The long bolts should have been about $8 so what else is in there?
Old 10-27-2008, 10:06 AM
JoeBlank's Avatar
Here ya go. The large AN fittings make it expensive...
1.000 AN3-4A BOLT
3.000 AN3-42A FOR OIL COOLER MOUNT
8.000 AN960-10 WASHER (AN3)
2.000 AN822-8D ELBOW 90DG TUBE-PIPE
1.000 AN823-8D ELBOW 45DG TUBE-PIPE
1.000 AN816-8D NIPPLE, TUBE-PIPE
4.000 K1000-3 PLATENUT 10-32
Joe Blank
RV-6
IO-320-D1A
Old 10-27-2008, 11:03 AM
Brantel's Avatar
Joe,
Always good to see the factory guys patroling the forum! Thanks for your super quick answers!
Old 10-27-2008, 07:45 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Other considerations
Brantel, if you use a real Stewart Warner cooler the Vans doubler does not fit. I presume it fits the SW "style" cooler that Vans sells. You also might want to consider using steel AN fittings rather then the aluminum AN fittings that Vans provides.
Also, before you get to far into mounting the cooler, you may want to consider additional bracing on the baffles in the the left rear corner where you mount it.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 10-28-2008, 05:37 AM
Brantel's Avatar
Thanks Rick,
Two friends of mine started with the Van's cooler and swapped to the real thing. They were able to tweak it a little and get it to work fine.
Will think about the steel fittings. Those are some big fittings so I am not as worried about them as I would be a smaller one.
Not sure when they added it, but the newer baffle kits come with a reinforcement brace that I have not seen on the older baffle kits. Did yours have this part?
Old 10-28-2008, 08:16 AM
Rick_A's Avatar
Default Yes, new style baffle kit
Yes, I have the new style kit. Here are a couple of photos I took before I finished. I may have beefed it up more then necessary but I was told this is a very high stress area.
In the corner by the cylinder, I used a piece of .063 1.5x1.5 pre-formed angle (p/n 03-48700 from Spruce) instead of the doubler that Van's provided. You can't see it very well in the photos but I also used 2 more pieces of the .063 formed angle to make a sort of "Z" on the inboard corner. The pre-formed angle is has a rounded corner and fits the corners on the baffles very well.
It was a lot of extra work but I feel it was worth it for long term durability.
As far as the Steel fitting. The reason I switched is because my understanding is that using Aluminum fitting on the Aluminum Oil Cooler will result in galled threads and ruin the Cooler. In fact, I switched to steel fittings on many of my FWF parts.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 10-28-2008, 11:17 AM
Brantel's Avatar
Rick,
Thanks for the info and pics!
Old 10-28-2008, 12:31 PM
allbee allbee is offline
first off, the doubler did work for me, using the sw cooler 8406r. Next I was given a tip to put some of the black seal stuff for the baffle kit in between the cooler and the doubler. Helps with vibration and backs the cooler away from the cylender. You can order the sw cooler from ACS, along with that order the steel fittings, as I hear aluminum fittings are a no no.
