ARINC-429 signals (Need More)
I am wiring up a pretty complicated panel and it has a Garmin 530W, an Avidyne EX-5000, a Tru-trak Sorcerer and a GTX-330 transponder. I am trying to feed signals from the 530 to a number of devices, namely the Avidyne, a GTX 330 transponder and a Tru-trak Sorcerer. The 530 doesn't have enough GPS 429 OUT signals to drive everything, and I know I can double up the outputs on the out side, since the fan out should carry the load.
I have a couple of questions or possibilities
1. How many signals will the GPS 50 ARINC-429 signal drive?
2. Or, does anyone know if I can feed this signal to the Avidyne, and then get it to come out on other 429 output ports on the Avidyne? Is that possible?
I need to drive the 3 devices from the GNS-530, and I am concerned about just bussing the signals together.
Any help would be appreciated.
Roger
