Old 10-26-2008, 01:14 PM
pvalovich pvalovich is offline
Default Garmin XM Antenna Mount
Anyone know the size of the screws to be used to mount the Garmin 496 XM antenna? There are 2 tapped holes on the bottom but I can't find a screw that fits.
Old 10-26-2008, 03:41 PM
Kenny Gene Kenny Gene is offline
I experienced the same challange, disappoints me that we purchase Garmin products and they don't include the 2 small screws to mount the XM antenna,,, I went to the local hardware store and I believe they are 3mm?? They are metric anyway.
Kenny Gene
Old 10-26-2008, 08:11 PM
Ironflight's Avatar
VAF Moderator / Line Boy
can't say for sure, but all the screws I've used on the back of Garmin units are metric - just used some 4mm on a portable to attach the mount - the antenna is smaller, so it might be 3....buy a couple of each at Home Depot Aviation Supply and save an extra trip (to go back and get the right ones....)
Only useful info out of this post - they're most likely metric.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-26-2008, 10:06 PM
B737NG B737NG is offline
The GXM 30 Owners Manual lists the thread size as M3.
Paul
RV-8 Finishing
Old 10-27-2008, 12:11 PM
Default XM Antenna Mounting Screws - YGTBSM
Just talked to Garmin - after a long time on hold. Stupid me - I figured the screw size would be depicted on p. 1 of the GXM 30A Manual, where a "Unit Overview" is presented, along with a separate "Mounting Holes" label. Naw - the screw size (M3 x 0.5) is actually shown on p. 28.
The Garmin rep did not agree with me when I allowed as how their manual was hosed, nor when I asked them to send me a couple screws. Guess one has to understand $2400 limitations.
