Old 10-25-2008, 10:44 PM
cjensen's Avatar
cjensen cjensen is offline
Default Need a heat shield...
Do I need a heat shield with 1 3/16" between the pipe and fuel line?
Pretty sure I know the answer(s) I'm gonna get, but if I DON'T need one, it's that much less weight...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 10-26-2008, 07:09 AM
DanH's Avatar
DanH DanH is offline
<<Do I need a heat shield with 1 3/16" between the pipe and fuel line?>>
No. You need to re-route the line <g>.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-26-2008, 07:23 AM
AlexPeterson's Avatar
You could put a cabin heater there.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 10-26-2008, 08:49 AM
Mel's Avatar
Mel Mel is offline
Default I agree with Dan.
Try a 45* fitting on the carb.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-26-2008, 08:54 AM
cjensen's Avatar
Guys, this is EXACTLY per plans...there is no other way to route that line. It comes off the fuel pump, and has to go in to the carb from that direction. I have a 45* fitting on the carb. The plans do call for a heat shield, but I didn't know if one was necessary with the distance between the two.
Putting a cabin heater there would result in unnecessarily long SCAT runs.
Chad Jensen
Old 10-26-2008, 09:41 AM
Steve Sampson Steve Sampson is offline
Chad, in the FWF kit there was a heat shield for exactly that point. See here.
Its pretty hard to keep them far apart at that point I agree.
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
Old 10-26-2008, 10:01 AM
cjensen's Avatar
Yeah, I saw it in the plans...I was just hoping that 1 3/16" was a wide enough gap to not use one. I pieced my FWF stuff together, so I'll have to figure out how to make one...
Chad Jensen
Old 10-26-2008, 10:18 AM
Chad, perhaps you can add a bit of clearance just by tagging it a bit away from the pipe. Some sort of support.
Another possibility if it still bugs you is to add another short segment of larger firesleeve over the current one.
Alex Peterson
KADC, Wadena, MN
Old 10-26-2008, 05:57 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
I ended up buying a 90-degree fitting to give me a little more clearance out of the carb. I used the small heat shield supplied with the kit, and made another one the same size. There was still a short section of fuel line that was only 3 inches or so away from the exhaust pipes. Since I just applied a bunch of heat shielding to the inside of the cowl, I took a couple strips of that (super thick tin foil with adhesive backing) and wrapped it around the lower part of the fuel line. Probably overkill, but oh well.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 10-26-2008, 06:15 PM
cjensen's Avatar
Anybody have a pic of that heat shield that comes with the FWF kit?
If not, what's the best way to get the shield to stand off the pipe?
Chad Jensen
