I have one of mine in there, I forgot about that. I don't remember bending it much different than the standard one, maybe a little tweak here and there. Any dimensions someone gave you would vary depending on your hole location anyway. I would think you best bet would be to hold it on the side of the tank and emulate it's location on the rear baffle as best you can swinging it back and forth. After that you can bolt it on and listen for it to make contact as you rotate the tank. If it looks good on the side of the tank, and doesn't hit the tank when you rotate it, I'd say you're good to go.
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
