Originally Posted by Ironflight
I like how you de-emphasized the "A" Webb.....;-)
The A was supposed to just fit under the 7 so the wings had a straight line on the right side. Note quite but close. Not so much to de-emphasize but to make it fit. Not exactly as planned but still turned out well.
Yes Doug - you are to blame (and I like the result)
Bob - I debated on the antenna direction. Just happened to face that direction. Technically, it shoud be more accurate since the force of air springs the antenna back into a more conventional dipole instead of an V antenna. Probably doesn't make a hill of beans difference. I might change it later but too much other to do. BTW - wings, horz and vert stab got hung today.
