  #11
Old 09-05-2007, 06:54 PM
Noel Simmons's Avatar
Noel Simmons Noel Simmons is offline
In the past I would just place the switch in the panel, rotate so the anti-rotation washer makes a mark, using a #30 drill start to make a hole careful not to penetrate the panel. Using a pair of diagonal cutters reduce anti-rotation tab size to fit my little indent. Works great and is much easier.
Noel Simmons
A&P CFI
Builder of fine aircraft #27
www.blueskyaviation.net
Old 09-05-2007, 08:05 PM
szicree szicree is offline
Noel Simmons
A&P CFI
www.blueskyaviaiton.net
I feel like a jerk for pointing it out, but your web address is misspelled in your signature.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 09-14-2007, 06:21 PM
I do have creative spelling :>(
Old 09-14-2007, 08:10 PM
mgomez's Avatar
mgomez mgomez is offline
Default Nice trick
Nice tip, thanks.
I did something similar: I backed up my FrontPanelsExpress.com panels with a sheet of .062", and then made the anti-rotation holes in that.
In many cases, I didn't drill the anti-rotation holes all the way through. It doesn't take much to keep the switches from rotating.
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 10-10-2007, 01:18 PM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Question Anti rotation washer
Originally Posted by szicree View Post
Today I was installing switches in my panel and they all come with that little anti-rotation washer ... snip.
Steve Zicree
RV4 Wires
My switches did not come with the anti-rotation washer. Wish I had known when I ordered (do you have to order them separately?).
Who stocks these little guys?
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 10-10-2007, 02:02 PM
dan's Avatar
dan dan is offline
www.bandc.biz has 'em. Wonder if Stein also might have 'em?
Dan Checkoway RV-7
Old 10-11-2007, 05:25 AM
PaigeHoffart PaigeHoffart is offline
Default Previous Thread
http://www.vansairforce.com/communit...ead.php?t=6778
Old 10-11-2007, 02:53 PM
Lycosaurus's Avatar
Thanks for the info, Dan and Paige.
The switches I ordered from Steinair come with a hex nut and a knurled nut. BandC's switches come with a hex nut and anti-rotation washer.
Just called Steinair, and they don't stock the anti-rotation washers anymore. They used to have a ton of them on the shelf, but they weren't popular and nobody ordered them. They finally got rid of them... and then of course they get my call with my request :-)
I asked what they used to prevent switch rotation. They use buss bars to power the switches, which prevents the switches from rotating. They also have the star washers available, that can be ordered separately (part number SA811R, I believe).
BandC do have the anti-rotating washers, though I'll first check locally again. If I don't find them here, then I will add them to list for my next order at BandC.
Alfio
> 1,000 hrs tach.
